Standalone Torch Height Controller for CNC Plasma Cutting
Discussion in 'Laser Cutters' started by Retsaj, Oct 7, 2020.
  1. Peter Van Der Walt
    Have you considered debugging it yourself?
  2. MalCNC
    MalCNC New
    Works! Nice work thanks for the new video that I was wondering about how to connect it to my table but I see it's just has its own actuator. Cool project thanks for sharing.
  3. mjpcarbon
    mjpcarbon New
    Can anyone provide a schematic for the divider needed ?
    Or is there a good prebuilt unit out there for sale ?
    #33 mjpcarbon, Mar 7, 2021
    MarkVovo likes this.
  4. Heiko72
    Heiko72 New
    You could read the step and dir signals from your board with the arduino,recalculate them in the microcontroller and send them to the stepper driver. This way the arduino is the only instance controlling the z axis and you won‘t need two z axes. This is what the proma compact thc does.
  5. mjpcarbon
    mjpcarbon New
    Built the THC and it works however occasionally when my plasma misfires it causes a voltage spike which has cooked two UNOs so far.
    Any help,sketches or direction is greatly appreciated cause Im running out of UNOs
  6. ljvb
    ljvb Well-Known
    Opto isolated circuit design is your friend... :)
    Build your own..
  7. mjpcarbon
    mjpcarbon New
    See @ljvb reply above. Use optos to keep the dangerous spikes out of your Arduino.
  9. mjpcarbon
    mjpcarbon New
    I get how an optocoupler can protect but was under the impression they are ON or OFF and could not show the variable voltage needed to make this device work since there is a range of voltage being read not ON OFF ?
    Can an opto-isolated input be analog? and more research of your own: arduino protect analog input with optocoupler - Google Search and analog optocoupler - Google Search - they do exist. Regardless, the original circuit is devoid of some engineering approached protection. TVS, Isolation, etc are all a little flaky
  11. mjpcarbon
    mjpcarbon New
    OK im searching thank yo
  12. mjpcarbon
    mjpcarbon New
    So the divider is done with Zener protection and works great however now I realize that after a cut and the torch extinguishes and the torch lifts, Does anyone know how to keep the torch down for the next cut (ie a parts with multiple profiles)
  13. Touma02
    Touma02 New
    i have 2 questions :
    my plasma gys cut 45 ct give maximum 20Vdc in 20:1 so if I put 50:1 the analog input could be more than 5v (6,5 v) so is it ok ?
    my plasma give me a contact which means that the arc is ok. Do you think Is interesting to use it ?
    thank you
  14. mjpcarbon
    mjpcarbon New
    You cannot exceed 5 vdc or the board will cook
  15. Touma02
    Touma02 New
    Hello,
    i try to make my thc and i have problem with Settings views. I have to click more than 10 on button to change val (exemple min or max travel).
    Next button and Plasma voltage are correctly refresh.
    After search, i saw that the arduino don't receive correctly trigger.
    What can is it ?
  16. Franklin sirias
    anyone have diagram to divider circuit?
  17. Bengt Carlsson
    Hello
    Can you have both openbuilders Blackbox controller and THC controllers connected in parallel to the z engine or how do you do the most suitable.
    Bengt
  18. Retsaj
    Retsaj New
    Check out the build guide video. It's talks about multiple controllers at the end. Basically, you need another thc actuator
  19. Adam Chong
    Hey I’m in the process of building this. I know you have not incorporated it into Mach 3. I was hoping maybe you could help me to code a couple inputs and outputs to your code.
    First would like to use 2 inputs to arduino as up and down signals.
    Next would be arc relay. Input and output. Input would come from Mach 3 and output would activate the relay and start the arc. This way Mach 3 could do a probe for material and set initial height from the probe. Actually maybe don’t need the relay to go through the arduino unless the arduino was set to probe for a height.(edit: I think I was thinking arc ok to start thc control mode. Not to start the relay.)
    Anyways if the Mach 3 could send up/down signals to the arduino and do initial height settings and then be cut off from control after the arc ok signal is received then the thc could control z axis while cutting. I have found out how to have Mach 3 do what I’m hoping but not if I’m able to make the arduino do what I was thinking. anyways any help with a possible way of doing this will be greatly appreciated. Once I have all my parts and get the thc working then I will try to intergrate the up/down options into the arduino and Mach 3.
    #49 Adam Chong, Feb 21, 2022
  20. Bob H
    Bob H New
    Had the same issues as you so changed to an UNO and your files and it works perfect, thank you. One thing i did notice though is that there is no other screens than the main and plasma screen, no next and back button, was this intentional?
  21. SmokyMtnRed
    One thing I have not completely wrapped my head around with the THC solution. Since it does not talk to the main plasma controller... When you start a cut, do you place the torch at a sufficient height to get things started, and after the torch pierces and starts cutting the THC controller will then maintain the height per the setting in the THC controller? I am assuming that you can't have the torch at a random high setting and it will adjust down when the cutting starts.
  22. Thcarney
    Thcarney New
    All the videos are private now. I watched them last week and bought everything needed. The videos were great, and to be honest, I think I’m going to need them. Thank you!
    Johannes B. Soffen likes this.
  23. Josh Kramer
    Do you have a link or can you tell me how I can watch the video? I'm getting ready to start on my first CNC plasma project and would really like to use this THC setup, but very new to all of this. Thanks in advance!!
  24. Josh Kramer
    Hey Retsaj! I am extremely interested in your build. Could you let me know how I can obtain permission to view your YouTube videos? I greatly appreciate it and the work you put into this project!
  25. Chris Wright
    Is there a link to your design somewhere?
  26. WGyver
    WGyver New
    Wonderful build!
    I'm in the process of building one of these, following your build instructions. I have a question about the initial height setting. I see how it moves the current position up and down as I adjust the pot (simulating the plasma cutter) but how is the initial pierce height set?
    I was thinking of modifying the THC to do the following:
    The CNC controller moves the torch to the XY position where the cut should start. It would then send a signal to turn the torch on. (This would now go to an input on the Arduino.) The Arduino would lower the torch until it touches (or better a sensor touches) then it moves it up to a set pierce height. Once in position, the Arduino fires the torch, and after a set delay sends a signal back to the controller to un-pause the G-Code. Once the cut is finished, the controller stops sending the torch "on" signal, the Arduino pulls the torch up to a preset rapid move height, ready to be moved to the next XY position to pierce again.
    I saw on one of your videos that you have a height sensor attached. How are you incorporating it since I understood you to say that only your THC is in control of your Z stepper motor.
    Has anyone tried this with the Hale Design?
  27. Matt K
    Matt K New
    I'm new to the Arduino stuff and even most electronics, but I am a tinkerer and I just built a CNC plasma that has touch off capabilities. With good flat plate or a drag tip and my floating head, it cuts great. But the drag tip isn't perfect. Ran across the videos for this THC a week ago and had another idea. I tied it into my existing GRBL controller using a relay module. Basically the GRBL board has control over all functions until the torch fires. The signal that closes the relay to fire the torch also enables the relay module to give the THC unit control over the Z motor after touch off. When torch stops firing, Z control reverts back to the GRBL board. Testing with a POT, the system works. Need to get my plasma cutter set up with a voltage divider and see what happens there, but it should work just fine.
    Had a thought while driving today. I am using an Arduino Mega 2560, and saw the breakout board shield for the mega. Now I am wondering if the GRBL and the THC sketches can be combined into one and function with less components and less points of failure. I figure the worst that happens is I let the magic smoke out of a Mega. Think I'll try the cheaper Elegoo version. I got one of them working for my THC. Had to change the values that ran up to 800 and keep them under 500, but it worked. If I get the cheap one going, a good one should handle it just fine.
  28. imach3232
    imach3232 New
    So how did you isolate the current from the plasma cutter from your muicrocontroller input pins?
  29. imach3232
    imach3232 New
    That is overly complicated and completly unneccessary. You can accomplish the same in gcode with G38.2 command.
  30. David the swarfer
    probably not, the mega is only running at 16mhz and the gRBL code is highly optimized to be able to run at all at that speed.
    Adding more processing is likely to break it.
    However, you should be able to easily create a plugin for grblHAL which runs on much faster 32bit processors that can handle the extra processing.
    grblHAL
