Cutting depth issue
Discussion in 'OpenBuilds Forum Help' started by JON D, Mar 11, 2021.
  1. JON D
    JON D New
    So I have finally completed assembly of my machine. I built it excatly like the original model part for part. I am using a x controller and easel to run everything. I have tried manually setting the zero on the material and also tried using a z probe. When I use the z probe it runs the bit through the work piece and spoil board. When I use the manual method it doesn't go as deep and I can run out a project but its deeper then the spec I set for cutting depth. Any help or thoughts would be greatly appreciated.
  2. OICITNOW
    OICITNOW New
    Just a thought...Did you calibrate it?
  3. JON D
    JON D New
    Not excatly sure what part or how to calibrate it.
  4. sharmstr
  5. JON D
    JON D New
    I'm new to this end of cnc stuff so is there a link to the calibration software and possibly like a step by step guide?
    Also do you know if there is a way to do it through easel or with the x-controller?
  6. sharmstr
    Sorry, missed the part where you said you were using the xcontroller. Anyhow, lots of info on their site
    Calibrate z axis (How to?)
    and
  7. JON D
    JON D New
    I got it calibrated today following the link and videos you sent. Seems to be working great now. Thank you very much for your help
