LEAD 1515, HGH15, SFU1604 Ball Screw
Discussion in 'CNC Mills/Routers' started by Netechsys, Sep 7, 2020.
  1. Netechsys
    Netechsys Journeyman
    Started making side shields and tops tonight. Cut the left side, and started bolting it together. Cutting the side shields as one piece, 1524mm, that will cover everything from front mount to rear mount. Adding 2 rows of m5 screws through the plate to attach to the C-beams and to screw the exterior plate to the 1/4” spacer at the bottom and the angle at the top. The angle will also attach to the top of the c-beam.
    side shield attached temporarily. Waiting on the longer screws to attach it completely, but the side is attached to the angle and the spacer at the bottom.
    Putting as many screws as I did was probably overkill, but there is 1 screw every 100mm connecting to the frame, and between them a screw attaching the shield to the angle and spacer. So a screw every 50mm.
    Was happy to be able to cut from both directions on the long pieces and have everything meet up as designed. Have not done multi side cuts till today.
    new ball screws ordered, new steppers here, changing out everything when the screws arrive. The new design for the ball screws will be fixed on both ends so I will be able to drive quicker. Will also change end switches out to optical at the same time.
    also changed the shop vac out for a true dust collector with a separate cyclone, running a 4” hose while way through.
    Done a lot of aluminum cutting for work and loving the results!
    #121 Netechsys, Mar 6, 2021
  2. Netechsys
    New ball screw showed up today. Changing from the 1604’s to 1610’s. At the same time, adding some new parts to the machine. Linear rail brackets to remove the through screws that come through the c-beams. New milled mounting block for the ball nut to the plates, new end plates for x/y axis to allow for new ball screws to be fixed under tension.
    This will allow both ends to be hard mounted. And at the same time will make the end plates a bit thick to allow a one piece mount to the C-beam and the 2040 frame across the front and back.
  3. Netechsys
    Cutting new c-beam end plates tonight. 1st one done. Not exactly happy with it. But it will work.
    If the 2nd goes better, I’ll recut this one. But you can see what I’m doing.
    8F3DDBCD-0F80-4AC2-83A8-09884AE597AE.jpeg E717A8C6-9350-44C9-BD10-2C25637AF817.jpeg
    Basically taking the BK12 fixed end that came with the new ball screw, taking the retainer/spacer/and bushing and mounting it to the new plate. The bearing that I’m using is a dual row sealed angular contact bearing with the m12 nut. This will lock the ball screw in nicely.
    Anyone have a recommendation for how to coat the aluminum easily. anodized/power coated/etc.
    One of my colleagues here at OpenBuilds made a tutorial video a while back:
  5. Netechsys
    New end plate mounted to screw. 1 double row angle contact bearing, 1 thrust bearing, all locked in place with with the 12mm nut and set screw. This will allow me to put some tension on the screw.
    9619985E-E0E0-4FAE-AE35-FFF9D9620DF2.jpeg 15800E3C-9777-4187-AB11-DE0C0EAC9BF9.jpeg
    Now to install them.
  6. Netechsys
    86A3528A-471C-4CD7-BEB1-EB6CDE305409.jpeg 79F6E657-CC87-4AA6-AE33-F5FB056FD1B9.jpeg
    New brackets are completed. Decided to make new mounts for the motors and make them for both nema23 and NEMA24’s. The 23’s will mount rotated 45 degrees.
    installing tonight. Need to go get some more screws from the local HD.
  7. Netechsys
    Building a new controller based off of the GRBL-ESP32 and the 6-pack board. This will allow me to add a rotary A-axis.
    I’ll post more after the different modules come. Changing from a 0-10v control for the spindle to an rs485 and one relay for a 4 pack 5v output module.
  8. Netechsys
    New controller finished. Staying with the 0-10 for now. Added more 5v signal ports. Can now control 5 external IoT devices independently. 4 end stops, one on each of the Y axis so I can do gantry squaring, probe, start, hold, and a enclosure door switches.
    will be installed tomorrow or Thursday night and then we’ll see how it handles the work.
    I have room for 2 more steppers, so I will be adding a rotary now.
    So nice seeing some old school wire-twisting anti-noise strategies :)
  10. Netechsys
    It’s either twisted, or shielded. I don’t want to have problems with emi in a run. And I’ll even isolate the power feeds onto different circuits for the different power feeds. (1 for the 48v power supplies, 1 for the 12v power supply, and the 220v for the spindle.)
  11. ljvb
    ljvb Well-Known
    Did you manage to get autosquaring to work? People on the discord channel have been having issues with it in the past, although I think a number of them were trying to use the switchless trinamic driver function.
    Which end stop sensors are you using just out of curiosity.
  12. Giarc
    This is great. I would love to do this for my C02 laser.
  13. Netechsys
    i am using optical end stops.
    I have one on the bottom of the X axis on both sides to work for the Y axis’s. Just have a small angle mounted at both end on the Y to trip the sensor. For the X/z, they are attached to the X/Z plate and same angles on the X/z axis to trip. These are normally closed, so adds a bit of protection. If there is a switch/wiring problem, it will open the circuit and stop the machine. And, since the switches all have their own signal port, I know which Y axis switch is erroring out.
    as for auto squaring. I’ll let you know when I install the controller tonight/tomorrow. And. A nice thing is that Bart lives in the local area, so if I need something it takes 1 day via mail. Normal snail mail.
  14. ljvb
    ljvb Well-Known
    Funny.. it took longer for Bart to ship my 6 pack to me than the guy in Denmark shipping my spindle mount (43mm for AMB spindle). They shipped the same day.. (Bart shipped it the day I bought it, I probably could have worded my statement better, I blame USPS. )
    If he is local enough.. you're better off driving to him than trusting the postal system.
    I'm only using the original 3 for now, but plan on going to 6 when I figure out my long term plans. Right now it's between the Piranha (I really like what they did), but the cost of the components and getting the plates milled to upgrade my lead1010 is approaching the retail cost of the cnc4newbies upgrade kit...
    I'm kinda torn at the moment
  15. Netechsys
    Playing hookie today. Decided to start putting the new parts on.
    789FFCE5-EBC7-48FE-9192-6334585349EE.jpeg C01910A4-2FD7-43BD-B64A-DD3EB0EBE0EC.jpeg 57EE9EF1-3573-43D9-8F3B-DBCF2DDCB03B.jpeg 52AC2D8B-D485-466B-B478-F4B540242C12.jpeg
    Liking the results!
  16. Netechsys
    Did a quick hook up tonight of the new controller setup. Ran a job and am happy.
    when I did some initial testing earlier this week, I didn’t like the heat in the enclosure, so I added bigger fans, 2x 120mm, on blowing in one blowing out. Also added 100m40x20mm heat sync on the stepper drivers.
    Need to clean up the wiring but. Temperature is nice. Hottest the stepper drivers got was about 30c, before it was about 48-50c. So big reduction in temperature. CPU on the controller was running about 56c, and now it’s about 48c. Fans for the controller will be here tomorrow.
    I havnt run the full speed yet, and I don’t think I will try to find the max speed. I did a quick back and forth on the Y axis@ 8000mm/min, 0-1300-0 x10 times, and the start and stop position was perfect.
    Should be completely done with the additions tomorrow. Need to finish the X axis. (Change ball screw from 1604 to 1610.)
  17. MakerMike
    MakerMike New
    The machine is beautiful. Absolutely amazing Having just read this all in one go, and seeing the evolution is really amazing. I'm amazed at the amount and depth of knowledge both you and other posters have.
    Thank you so much for creating this thread and supplying so much detail. Excellent discussion as well which was quite helpful! I'm working on implementing my first ball screw (not a cnc machine) and the hardware mounting aspect has baffled me. I think I understand better about the gantry spanning the screw and connecting to the guides and mounting the screw ends. It seems so easy to buy an 8mm ACME threaded end for 2040, but it seems like for a 16xx screw it needs to be fabricated. (please, please correct me if I'm wrong).
    I bought a 1610 screw which came with the standard bk mounts just to evaluate (play with) them. I was hoping the screw itself would be all i need for rigidity (no additional rails guides) since my project has huge tolerance for shift etc. I've been doing software / working with microcontrollers to drive various motors for many years and for too long I would code what should be done in hardware (accuracy / safety) but I've never build a CNC machine (yet).
    Again, many thanks and congrats on your machine!
    -Mike
    (EDIT - I just saw 6600 drivers are discussed here in a separate thread, so moving this to the bottom to be ignored)
    I know you've moved on from the 6600 drivers - but to reiterate a reply I read here and for anyone else considering them, the main issue with these are you don't know what's inside. They range in price from $9 to over $20 on Amazon which should raise some red flags on its own. The PWM signals that drive motors need to be optimized - for example if you hear a whine, the PWM frequency is wrong. You can use an arduino with the default PWM example, and run it with different frequencies to actually hear how PWM creates noise when it isn't optimized. The ~$150 'bullet proof' model gecko drivers pretty much will catch any coding errors that could harm a motor. but they are too expensive outside of a testbed. I usually have a requirement to be able to control 3 or 4 motors in each of my projects so I couldn't invest in 50+ gecko drivers, so I built a bunch of control boxes (each has 4 sets - at $2 per set - of 2x400w mosfets connected to an $8 ESP32 with Blynk functionality added so you get instant mobile app control for free and all the connections are aviation or DC 5.5 dumped into a 3d printed box with a $5 OLED debug display)
    #137 MakerMike, Jun 27, 2021
  18. Netechsys
    The BK/BF end mounts are good. They just need to have the alignment set and be precise. If you can get them aligned correctly, and keep everything square, they will work great. I went to the custom end plates to get everything more precise. And the outcome has been great for me.
    since changing to the captive ends on both ends of the new ball screws, I have really had some great success. I have changed both y and the x to 1610 screws and the speed and power of the all axis’ has increased. Ok, maybe it had to do more with the new closed loop steppers, but I’ll put it as a combination of all.
    I’ll post more on the end results shortly, work has been nuts.
  19. Silver_Sen
    Very nice build, I just start a new build inspired by you, y1600 x1480, not sure about the z yet. Few difference from your, will use SFU2510 and steel custom end plate integrating two FK20 style bearing support.
    Here is my question I running into, when you drill holes for mounting the HGR rail onto C-beam; how do you able to to ensure they parallel though all?
  20. Netechsys
    I created an aluminum plate to use as a template to drill with. I have changed the design a bit since my last post and used the template as a mounting plate for the linear rail. It added an additional amount of rigidity to the c-beam. These plates were made on the machine.
  21. Silver_Sen
    Would you mind upload a picture?
  22. Rhett E
    Rhett E Well-Known
    @Netechsys How are those 1604's working in regards to speed?
  23. Netechsys
    Been a while since I have upgraded anything on my machine, so I started a new project. I am changing the Z axis to a more rigid axis and reinforcing the X axis. I am also adding some protection to the X axis to keep dust and aluminum chips away from the Linear Rails and screws. This is the Z axis ready to mount and a new Drag Chain tray that will attach to the top of the X axis. The Drag Chain axis will stiffen up the top C-Beam quite a bit, and will add the same to the bottom of the bottom C-Beam shortly. This change will allow the last of the open loop stepper to be changed to a closed loop.
    This has been a fun project from beginning to end, and I have learned a lot from this community. I greatly appreciate the help that everyone has given me over this project!
    Last items to add to this and call it done is a rotary axis and a High power laser diode. I am looking at a 30W Blue laser that will do just about everything that I could need it to do!
  24. Binoy
    Binoy New
  25. Binoy
    Binoy New
    Do you have dxf files for the plates
  26. Netechsys
    I bought the ball screws from a Chinese company. They custom made them for me because I wanted different end geometries than standard, so I could do a captive end to n both sides and put the ball screw under tension. Similar to the tensioning for some acme screws.
  27. Netechsys
    Which plates do you want files for? I have them in Vectric Aspire, so I could export the dxf.
  28. Binoy
    Binoy New
    Gantry plates
  29. madelu
    madelu New
    HI,
    I love your design so I'm trying to develop my own project taking inspiration from your work. May i ask you in which chinese company you bought the custom ballscrews and what modifications you made to them?
