Sigron IDEX
Discussion in '3D printers' started by Troy Joachim, Aug 22, 2020.
  1. Troy Joachim
  2. eliteSCHW31N
    Hey there, can you please share your step and stl files?
    Muhammet001 likes this.
  3. Vasco Rocha
    Hi guys! ;) loved this idea! Idex is really a handy machine. Make it 2 filaments on one print, or 2 prints at the same time, the interesting is that such a machine can produce small pieces at twice the rate of others, love it! Print 2 colors... love it! So having a cubed machine with a fixed bed and therefore a mass gravity center at the right spot... love it. Just don't love the space we "waste" on the bed to do such a thing like this. The cartesian style on a cubed machine is an old idea i have and currently I just swapped my idea of a Cartesian style like this to a CoreXY because I already have some architecture that will be blended to make a corexy based on the layerfused x301 style. Great machine you have there. I would like to know if there is any 4 gantry style (I know voron2 does it) but that can handle now 2 printing heads in idex keeping the idex functionalities of double print, mirror print and double color print. If that so, I would just suggest to try making the bed a bit longer (on Y)... maybe we could put the motor outside the cubed frame. Now you have it inside the cube, but if you try to put it outside the frame you can make the bed longer on the Y direction.... every mm counts :) And about the X, if we make narrower print buckets, maybe you could put 15mm each side on the X travel.
    If you have step or stl and could share maybe all of us could contribute with ideas and turn this idea into a working machine. Thank you Joachim for this idea. I also love voron design! :) Great machine design, probably the best one around. Keep up the good work mate!
  4. Vasco Rocha
    just making sure i am following this project :)
  5. d_a_n
    d_a_n New
    Did you manage to go ahead with this? I was thinking to try to use belts and replace the screws and have a locking sistem when homming.
  6. Brian Hutchinson
    I'm potentially looking for designers/builders of IDEX printers to perhaps try a new utilization of the IDEX system for a new type of pellet/filament utilization. I own a Sovol SV04 which I plan on using as the first test platform and am sending out feelers for other possible platforms in the future. If this project/designer is still active please let us know.
    thanks
  7. Brian Hutchinson
    *** I got an email saying that (one) Hubertalece replied to this discussion. Where is that then?
    Was just a random spammer, banned by one of our moderators. Just part and partial of daily cleanup - always a chancer or two.
