Calibrate CNC 3018 Pro
Discussion in 'CNC Mills/Routers' started by nightearth, Mar 29, 2021.
  1. nightearth
    I have bought CNC 3018 Pro from Amazon. I have assembled it successfully and I can see it going right and left and up and down, but everything is moving on the opposite side.
    I will attach copy of the board and machine if you do not mind.
    I am facing several issues with this CNC machine:
    - moving on opposite sides as I mentioned above (lightburn) . I typed this code G10 L2 P1 X-300 Y-180 on the console and it is still the same.
    - I won't be able to control the CNC from computer once I plug the control into the Arduino board.
    - Grbl 0.9j ['$' for help] ( I am wondering if this is the firmware and if I can upgrade it please)
    Please help me to sort out these issues.
    Thx in advance
  2. nightearth
    I just download your new application because I was facing several issues with LightBurn.
    I am able to connect the machine to your application, but when I press move right, left, up or down I got the attached screenshot error.
    I appreciate your help.
