Slow down workbee travel
Discussion in 'CNC Mills/Routers' started by Barzalou, Apr 4, 2021.
  1. Barzalou
    Barzalou Well-Known
    Hello,
    Could someone tell me how I can slow down the default travel speed of my Blakbox controlled Workbee when it moves in the Y-axis direction? The way things are going, when I move the gantry from one side to the other of the CNC, it studers a few times.
  2. sharmstr
    Go into grbl settings tab and lower your Y max rate. Its $111
    Barzalou likes this.
  4. BKramer
    BKramer New
    Just had this problem, stuttering on Z. Tried all the software solutions and no change. Finally figured out it was positional (it worked on one side of the x travel but not the other) and found a short inside the z stepper cable (from openbuilds). Spliced it out and ordered a new one from Amazon.
    Barzalou and Peter Van Der Walt like this.
