Connected but no control
Discussion in 'General Talk' started by Flyinb, Apr 1, 2021.
  1. Flyinb
    Flyinb New
    Just finished my work bee 1500x1500. X pro 5 controller, Openbuilds cam and control software. Software seems to run correctly, computer connects to controller through comm 3 it seems but zero control, jogging ect. Am i missing something? or could the X pro 5 be DOA? When i try to jog i get the message "Took a couple pictures of the screen as well. Please wait for machine to be idle before jogging" what does that mean?
    Thanks, Bruce
      File size:
      230.6 KB
      69
      File size:
      209.7 KB
      65
      File size:
      156.8 KB
      82
  3. Flyinb
    Flyinb New
    Thanks Peter, Will try another control software and see what happens, maybe CNCjs? Guess i am really lagging in the software knowledge department.
  4. sharmstr
    According to Spark Concepts website, that's what they suggest. CNC xPRO V5
  5. Flyinb
    Flyinb New
    I tried CNCjs as well, I really am missing something here LOL. I thought you just hook up the computer, start the control software and go, not working that way. CNCjs connected no problem but no controlling, curser just turns to red circle when i hover over control buttons. Built a cnc plasma cutter years ago that ran on DOS, kinda thought this would be more plug and play i guess.
  6. Gary Caruso
    Post your $$ settings here, many people get tripped up with $4=1 (needs to be or it will never move)
    Take any limit, coolant, door, or home switches wires off until you get things moving right.
    Did you double check your motor poles and not just use the colors?
    Gary
  7. Flyinb
    Flyinb New
    Thanks Gary, Not exactly sure what "$$ settings" are as i am just learning this thing but i think i figured out the problem, motor wires are all correct as well as the other wiring. I think the problem is with the E switch, did not check if it is N/O or N/C, i think there may be a conflict with it and how the controller is set up for it. Will check it out after the coffee kicks in this morning.
    Bruce
  8. Flyinb
    Flyinb New
    Got it sorted out, it seems the laptop i was using has a bad keyboard, switched computers and seem to be working fine, just need to learn how to operate it properly.
    Bruce
  9. Allistar
    Allistar New
    I use the XPro V5 with my Lead 1515 machine. I use their web interface (ESP32) to set grbl settings, and I use CNCjs for running GCode files, homing etc. The combination works well, though I've had issues with the touch probe.
  10. Flyinb
    Flyinb New
    Hey Allistar, Sounds like we have very similar setups as i have a 1515 workbee. I am using CNCjs as well and barely have a clue of its functions at this time. Not sure i completely understand the purpose of the ESP32, seems you can change settings with CNCjs, sure i am missing something.
  11. Allistar
    Allistar New
    CNCjs seems more configurable and gives better visualisation of the pattern being cut. You can use ESP32 to run gcode files though. One benefit is you can use ESP32 using wifi but I think CNCjs needs to be connected with USB.
