error:22
Discussion in 'General Talk' started by hixnhix, Jul 11, 2020.
Tags:
  1. hixnhix
    hixnhix New
    i am using vcarve to write g code to lead machine and all the sudden
    error:22 feed rate shows up how can i fix
    Would help if you post the file :)
  3. hixnhix
    hixnhix New
    I cannot figure out if it is something in Vcarve or in machine driver? It maybe coming from the IOT switch I just added.
    Its a g1 move without a feedrate. Nothing to do with IOT.
    Post the vectric project, post you used and resultant gcode.
  5. hixnhix
    hixnhix New
    Thanks will do
    Error Code just posted similar issue, so might be related to a Vectric update? Also check which version you are on please and report back along with the files
  7. hixnhix
    hixnhix New
    Might be Just installed new version of software, waiting to hear from Vectric
    Good, but which post processor are you selecting, so we can also help escalate (as we are a reseller) if they need to fix a post :)
  9. Alex Chambers
    I tried some simple files using the grbl (mm) (*.gcode) and Openbuilds (mm) post processors and they seem to be working OK. As @Peter Van Der Walt said share your Vectric and g-code files with us and let us know what post processor you are using.
  10. hixnhix
    hixnhix New
    Simple house number on lexan
    Refer above please... Which Post are you selecting from the list of posts...
  12. hixnhix
    hixnhix New
    Open builds inch
  13. Alex Chambers
    When you upgraded Vectric did you migrate everything from your previous version (especially post processors). I did mine so I can't check if the upgrade includes the latest version of the Openbuilds post processors.
    Try the mm posts as a test?
  15. hixnhix
    hixnhix New
    just did same error
    Try the Grbl-mm one, worked for Error Code
    The OpenBuilds posts reference the Grbl posts and then make adaptations, so if the Grbl-inch post is broken in latest update, it spills over into ours
  17. Alex Chambers
    Vectric claim (today) that the latest release fixes the grbl post processors - they don't mention Openbuilds or Duet versions.
    They won't, because we "include" the Grbl posts using the POST_BASE option: See OpenBuilds/OpenBuilds-Vectric-Postprocessor and OpenBuilds/OpenBuilds-Vectric-Postprocessor (line 46 in both)
    So when they broke the Grbl posts, the others are affected too.
    Essentially POST_BASE is an inheritance type directive. It would save having multiple copies of what are essentially the same lumps of code. The GRBL based post processors do the same thing. You can add any commands that are specific to your needs after the POST_BASE command - in our case customised the headers, adding a spin-up delay for the spindle after M3
  19. JerryG
    JerryG New
    I am VERY inexperienced and having this same problem -- Running Lead 1010 on black box w/ Cut2D Desktop and getting Grbl Error: 22 Feed Rate has not been set or is undefined [G1Z=0.500] . IF I understand the above thread, I need to get the fix from Vectric. Is this correct?
  20. Alex Chambers
    This issue should be fixed in the latest update from Vectric (10.54)
    What post processor are you using? Let us know if it still doesn't work with the latest update.
  21. hixnhix
    hixnhix New
    working with 10 today will try tomorrow
  22. Michael_S
    Michael_S New
    Hate to reopen this but I’m seeing it when running the built in spoil board program.
  23. Peter Van Der Walt
    If you do get the same error, then you forgot to type a number into the feedrate input field of the wizard. Enter all the values then generate Gcode.
  24. Michael_S
    Michael_S New
    Nope, it was in there. Ran for half the job and then halted with that code.
  25. Peter Van Der Walt
    Thanks, including sample files, screenshots and additional details like the "it ran till halfway" would always help avoid situations where we have to make assumtions.
    As this tread was about GCODE where the feedrate was missing because of Vectric bugs (so not the same as your issue then) it would be best to have a detailed problem description to work from, just a tip for next time.
    If it ran halfway then, including the Serial Log of the run up to the error, along with the file would help us take a look for you
