Makita Router Mount
Discussion in 'CNC Mills/Routers' started by gregers05, Oct 7, 2019.
  1. gregers05
    gregers05 Well-Known
    Not sure if this is the best place to post this or not, but I have mentioned before that it would be nice to have a OB mount made for the Makita RT0701C as an alternative to the Dewalt router. A lot of people seem to prefer the Makita over the Dewalt because it has a larger range of RPMs. I am running the Makita on my LEAD with a 3d printed spacer, however it isnt quite as secure as the mount with no spacer, you really have to tighten the screws. It is another varible to consider when tramming.
    What are the chances we can get a Makita mount from Open Builds? It is probably easier said then done, but I would think it would be pretty easy to produce, it would just be a slight change in the ID of the mount.
  2. DarkPenguin
    DarkPenguin Well-Known
    65mm ID. If you know someone with a CNC you could have them mill you one.
    gregers05 likes this.
  3. sharmstr
    Contact Chris Laidlaw. He makes mounts for the makita. Chris Laidlaw
  4. Rick 2.0
    Google search "65mm cnc router mount". They are readily available in the OpenBuilds style.
    gregers05 and sharmstr like this.
  5. gregers05
    Thanks guys, I will give one of these a try.
  6. Andreas Bockert
    Andreas Bockert Well-Known
    Also check out the 65mm spindle mounts found on eBay. You might need to figure out. Way fasten them to your machine yourself but they’re way beefier than the openbuilds. For OB style I would recommend to if you can fasten them both.
  7. gregers05
    Yeah I found the same ones on eBay that were on Alliexpress but with faster shipping but $15 more. I dont mind waiting a few weeks to spend a little less. I may eventually get a second one, but I can run my current one with the 3d printed insert also. Figured I would wait and see how this one fit before I ordered a second one.
  8. Andreas Bockert
    The one I had fit very well. The problems with a single openbuilds is that he contact area at the back plate is narrow and generates quite a big bending forces on the back plate. (It won't bend it enough to deform but the if you pull the router it's easy to make the back plate flex 0.1mm)
    However, the big ones found on ebay (I.e. 65mm/80mm Diameter Spindle Motor Mount Bracket Clamp fit CNC Router Engraver US | eBay) are a whole different beast. However, you'll have to drill your own mounting holes which may or may not be possible depending on your setuyp.
  9. BSmith
    BSmith New
  10. JustinTime
    Do yourself a favor and use two clamps to hold the router and not one. Install them as far apart as possible.
  11. Christian James
    Christian James Journeyman
    Yes, I got a bit desperate for a Makita mount at the time so imported one from China. It proved to be very good quality, well machined and well finished. Perfect for my Makita.
    #11 Christian James, Apr 9, 2021
  12. DarkPenguin
    I bought two of the ones from china. Then I made a plate to mount them to. It is also setup to make it a little easier to tram things.
