Workbee with less irritations
Discussion in 'CNC Mills/Routers' started by DarkPenguin, Apr 12, 2021.
  1. DarkPenguin
    DarkPenguin Well-Known
  2. Mark Carew
    Hey @DarkPenguin really nice mods! I especially like the way you did the breakout for the BlackBox
    Thanks for sharing your builds and these helpful tips
  3. DarkPenguin
    Thanks! I'm reasonably pleased with that panel and the overall box should weigh enough to prevent me from catching a wire and ripping it out. I wonder how hard it would be to run light pipes (or whatever they are called) and direct all the LEDs from the BB and PSU to that panel. I'm still working on the air filter bit for the back. (I should have made it 12"x12" and just bought a 12"x12" filter.)
    I like the workbee a lot.
  4. DarkPenguin
    Added STL files for the stops and whatever else went into this. Some things are missing because they are probably attached to an unrelated fusion file cause that's how we do things now.
