Blackbox 4th axis
Discussion in 'Controller Boards' started by Mouss, Jan 4, 2020.
  1. Mouss
    Mouss New
    Hello All,
    The Blackbox Openbuilds has only three axes,
    Can I do this type of connection with MTS402 switches, in order to have a rotary occasionally
    if this is not possible are there any specific reasons?
    Thank you in advance.
    Video is kinda hard way to check wiring diagrams so consider the answer as 'didn' t check it'
    But a) Power Off before disconnecting/connecting motors! (switches will be the same as a hard disconnect) else the sudden collapsing field in the motor windings can fry the drivers
    b) Grbl is 3 axes only, but yes Vectric for example calls it Rotary Wrapping where it reuses X or Y as a rotary axis. Most folks unplug for example Y, throw down the rotary jig, plug it into Y and go!
  3. Mouss
    Mouss New
    thank you, you mean you have to handle the switch before powering the Blackbox?
    At all times, when connecting or disconnecting anything, power off first! Particularly motors as the disconnect cuts the power to the coil, residual electromagnism collapses back into coil, coil becomes a generator, voltage comes back to the driver through that one pin that disconnected a little slower and boom dead goes the stepper driver
    Ken Battle likes this.
  5. Mouss
    Mouss New
    Thank you for this very useful information :thumbsup:
  6. stuart wallace
    I’d be really interested in a video / blog of what you’re describing in b). I’d love to see an open builds 4th axis package that works with black box and a high z mod lead 1010. Cheers
  7. Mouss
    Mouss New
    Hello All, here is the video of my 4th axis in action, I am happy with the operation, if you have any questions do not hesitate.
    Be careful, as Peter says, turn off the Blackbox before changing position (Y / Rotary) or (Rotary / Y)
    #7 Mouss, Apr 3, 2021
  8. baum
    baum New
    Which controller software is that? I assume you just send your y to the axis of the rotary prior to flipping the switches? what rotary unit is that?
  9. sharmstr
    If you look at the upper left part of the screen you will see that its CNCjs
    baum likes this.
  10. Mouss
    Mouss New
    baum likes this.
  11. Blacksmith74
    Found you video interesting, we are about to purchase a blackbox to use with our small CNC with a rotary axis. In your video i can see you are using aspire, have you tried using aspire for loading 3D models to cut with the rotary, if so how did you get on and what post processor did you use. I would be interested in anyone who has done this as this is what we are hoping to do.
    Im also interested in the software that you use after Aspire called CNCjs. Why do you use this ?
    We also have a larger built driven CNC and notice you use a belt tensioner, could i ask where you found those and how to fit them.
  12. Mouss
    Mouss New
    Yes it is possible to import a 3D model (see photos) it is very simple, then to export the Gcode I do it with the GRBL post-processor (see photo)
    For CNCjs I find it very easy to use after that it's a bit of a problem I think!
    For the belt tensioner it's homemade (DIY) and it does the trick with a square and a Vslot wheel ;)
    I hope I answered your question, if you need don't hesitate ;)
  13. Blacksmith74
    So the normal garbled will do the rotary, surely I need to modify the post processor
  14. Blacksmith74
    Sorry grbl mm
