XYZ PROBE AND THE HOLE
Discussion in 'General Talk' started by John kelly, May 10, 2021.
  1. John kelly
    I’m thinking of buying this device but I’m confused about the hole. It seems to me that it’s very easy to position a bit in a multitude of places within the hole. Because of that I’m a bit confused to how that works, can anyone help?
    Checkout video below.
    Regular probing (skip assembly, watch from 1min40sec onward)
    and Auto-mode that uses the hole too
    You position it above the hole, approximately.
    From there it first uses the outside edges to detect the bits location relative to the puck, then it goes inside safely by itself, to check endmill diameter, whereafter it can use that diameter to calculate and set the correct offsets.
    NB you don't have to let the wizard measure the endmill, this is Auto Mode. You can just type your measurements in yourself if you mic out your endmills.
    #2 Peter Van Der Walt, May 10, 2021
  3. John kelly
    Thank you, it makes sense now. :)
  4. sjashe
    sjashe New
    btw, I found the magnet was just not usuable. Would constantly slip off when probing x/y. I added an aligator clip probe wire I had around and that works much more reliably. I would recommend replacing the magnet witha clip in future versions of the product.
    Were you using it on the bit or collet. It sticks very well to the flat on the collet.
    Crocodile clips are dangerous (more so than the magnet) in case one forgets to remove it. Major part of the decision between the two
  6. sjashe
    sjashe New
    I was having trouble getting signal through some of the bits at the time, but I was newer at this.
    I'll try the flat of the collett at let you know.
    Thanks.. I have to say the support we get from OpenBuilds, both here and on the Parts store is very good.
  7. sjashe
    sjashe New
    Did some testing last night and you're right, it works well from the flat of the collet.
    I would recommend updating the image in the Probing wizard, I was following that at the time and having the magnet continually falling off.
    Thanks again!
