How to calibrate Z-Axis?
Discussion in 'Control Software' started by jeffmorris, May 9, 2019.
  1. jeffmorris
    jeffmorris Journeyman
    I have CNC XPro V3 board, DQ542MA Stepper Motor Drivers, and CNC router with ball screws. I use OpenBuilds Control software. How do I calibrate Z-Axis? I already calibrated X and Y axis. I found out that I have to use 316.032 steps/mm for X and Y axis. It is impossible to use a ruler.
  2. Alex Chambers
    If you have calipers that will measure depth then machine a pocket in suitable material (not wood - acrylic or aluminium for best accuracy) and measure the actual depth compared to the programmed depth. You need a fairly accurate measuring tool like calipers because you will only want to machine (say) 10mm or so.
    Aussie58 and sharmstr like this.
  3. jeffmorris
    I have digital calipers but I don't have acrylic or aluminum. I think I saw a video on calibrating Z-Axis using calipers but I don't remember which one.
  4. Alex Chambers
  5. David the swarfer
    ah! calipers!
    with those you can measure 2 things, 1 thing about .5" thick and another of 1 to 2" thick (depends on your Z travel). Ball races would be good. bigger difference is better.
    Then use the technique at 03:14 in this video to jog to the height of the small one and set zero there.
    Then set the height with the larger item (by jogging carefully as before).
    Now the GUI shows the 'commanded distance' and the 'actual distance' is the difference between the measured sizes of the objects you are using.
    Then you can use the wizard to calibrate, or just use the formula from
    C-Beam™ Machine - Plate Maker
    V1.0.166 or older of OpenBuilds CONTROL -> Connect to Machine -> Grbl Settings Tab -> Scroll down to $100-102 -> Click the "Fine Tune" button
    v1.0.167 or newer of OpenBuilds CONTROL (Coming out soon) -> Wizards and Tools -> Calibrate [x,y or z from menu]
  7. jeffmorris
    After trying to calibrate Z-Axis a few times, I jogged the Z-Axis so that it touches a piece of wood using a piece of paper as feeler gauge. I made a mark on the Z-Axis carriage. I used "Fine Tune" tool to move Z-Axis up 50mm. I made another mark on the carriage. I made marks on piece of paper. I measured the distance between marks using ruler. I entered the distance into tool. I found out that the steps/mm was 366.6667 so I changed it to 632.064. I cut out flowers from piece of wood and it worked.
  8. jeffmorris
    I think that the feed speed is too fast. How can I reduce the feed speed? I have VCarve software.
    In VCarve you need to edit the Tool, and change the parameters:
  10. John Fisk
    John Fisk New
    I have been successful at calibrating my 3 axes using the calibration program using OpenBuild Control macro and Black Box.
    My question is about precision. I am using a digital caliper in contact with a router bit. I zero out the caliper and run the Control macro. If i then repeat the process several times, while attempting to control all variables, I get a variation in the values. This does not surprise me, but what is an expected variation using the Control macro that I can expect and call this precision number good? I know that my application will drive the "goodness" of the precision. I am just wondering what the community is seeing and accepting as "good"?
    If i need to tighten up the precision of my machine where should I attack? I have lead screws on all axes.
    Thanks Ya'll,
    Texasinmi
    Check the following:
    - Couplers between motors and leadscrews are tight
    - Wheels properly adjusted
    - Anti Backlash Nuts properly adjusted
    - Frame square, level, and built as-perfect-as-possible (Its only as good as the guy who puts it together)
    - Motor current properly adjusted
    How much of a deviation are you seeing, some pics of the testing etc may help
  12. John Fisk
    John Fisk New
    Here are my results for ten runs using the X axis macro. I added a pic of my setup:
    Result of 100mm input Calculated $100 Value
    Start 319.736
    99.87 320.152
    100.18 319.577
    99.74 320.410
    100.24 319.643
    99.73 320.508
    100.02 320.444
    100.11 320.092
    100.14 319.644
    99.59 320.096
    100.25 320.160
    What is X Axis Macro?
    OpenBuilds CONTROL comes empty with no macros included, so no context to this?
  14. John Fisk
    John Fisk New
    My Control software (v 1.0.172) that works with a Black Box has a section where several macros reside. One will allow you calibrate the X axis, as well as Y and Z. It will ask you to input the zero location, next it will drive the X axis 100mm, you then input how far the machine actually moves then the macro will calculate the grbl value $100 for you and enter it into the Control for use on the next run. It is pretty slick.
    The values I sent represent the actual distance driven in mm and the $100 value from that distance.
    John Fisk
    This is MACROS:
    What you are referring to is under Tools and Wizards... Ie its a Calibration Wizard :)
    OK so that explains better what you did.
    So each time you redo the test you should be getting a little closer to true (provided you can help by hitting the reset button on the controller between runs)
    As its ballscrews though, I would rely on math, not on trial-and-error calibration. If you trust the screws you have... That way if you still have deviation at least you know its mechanical, not the steps value
  17. John Fisk
    John Fisk New
    My bad, it is under Wizards and Tools.
    What is the math you refer to having to do with ballscrews?
    John
    Example:
    Say you have the following hardware:
    - 4mm pitch screw (Advances the carriage 4mm for one revolution of the screw)
    - 200 steps per rotation motor (1.8deg per step, 200 steps per rotation (1.8*200=360))
    - Stepper driver set to 1/16th microstep
    Then calculate:
    200 steps per rotation * 16 microsteps = 3200 steps per rotation.
    One rotation moves the carriage 4mm (4mm pitch leadscrew)
    So to get 1mm of movement (steps per mm) we do 3200 / 4 = 800 steps per mm
    If its a metric screw, likely will be a round number
    Note I dont have the specifications of your screws or motors, or what microstepping your drivers are set to. So substitute accordingly.
    Metric screws should end up with a nice round number
    Looking at your trial results, I'd guess 320 to be the actual number...
  19. David the swarfer
    Unless they are precision ground screws they are never exact (most are made by a rolling process), you do need to do calibration for all screws. (but do start with the calculated number)
    Also, the process you use for the calibration makes a difference.
    I found that returning to 0 before changing the $10x values worked best. Maybe a reset is even better.
  20. David the swarfer
    those values are hovering around 320 with a slight upward trend. I think you are seeing measurement error more than thread pitch error (-:
  21. John Fisk
    John Fisk New
    Thanks for the feedback.
    The question I really have is "If you saw number like this out of your machine, would you be happy with them and leave things alone saying to yourself ""Wow, those are some tight statistics."" or would you work to make things tighter saying to yourself ""Wow, those statistics really suck""?"
    I really don't know where I am at on the bad to good scale of things.
    John
  22. David the swarfer
    I would cut stuff and see if there is a size issue on assembly.
    Can we detect when a bit of wood is 0.1mm oversize? I just don't know, yet...
  23. John Fisk
    John Fisk New
    Great suggestion
    John
  24. stuart wallace
    Hi there,
    Hope you're well. I recently had to change out routers (dewalt for makita). I did the calibration wizards for xyz. I installed the latest version of openbuilds control software. I have lead 1010 with high z mod. I started a profile pass in some mdf. Something didn't sound right. I checked with calipers and it was cutting way deeper than the .125 I told it to in aspire. Calipers measured .165. I recalibrated z and nothing changed. I looked at grbl settings. I have the default set for the lead 1010. I looked at $100, $101, $102 and clicked on the little calculators next to it. It says I'm using belts even though I'm using the lead screw. I switched it to lead screw, saved, then looked again and it still says belt driven. This happened after save / exiting out of the calculator and after 'saving to firmware.' I'm not 100% sure, but I suspect this issue is what is causing my calibration wizard tuning to be way off.
    It's not saving what I do anyway, but for when this issue is fixed, can you also provide the default measurements for all the fields in the xyz 'calculate steps per mm for xyz axis'... leadscrew type, motor type (I have the high torque nema 23), and microstepping type?
    many thanks for any help
    take care and all the best
    stuart
  25. sharmstr
    The calculator is a form you can use to get you close. The form fields default to belt but that doesnt mean your machine is set to belt. GRBL doesnt care or even know if you are using belts or screws. All it cares about is steps/mm. You shouldnt need to use the calculator if you loaded a machine profile. The machine profile will load 199.10 for screw driven.
    From there, you need to use the calibration wizard in the wizards menu. That will adjust (change) your steps per mm depending on the values you input during the wizard process.
    I would suggest that you start over with default values and run the wizard again now that you know what everything does and doesnt do.
