Router11 Question
Discussion in 'CNC Mills/Routers' started by BeeAMaker, May 16, 2021.
  1. BeeAMaker
    BeeAMaker Well-Known
  2. Giarc
    Actually, the Grizzly is a cheaper version of the Makita. ;)
    The Router11 has higher quality bearings and is designed for the ER11 collet. You get a few common sizes with it, but you can buy other ER11 collets too I assume and they are inexpensive.
    I have a Makita. It has been running great for years, but for me to get the versatility of the ER11 collet system, I needed to spend an additional $140+ on precision Elaire collets. Also, I have another version of a Makita clone for my lathe. I can tell you that I definitely notice it is NOT a Makita. If you do not want the RoutER11, I would spend the extra $20 and get a real Makita
  3. BeeAMaker
    Already have the ER11, no complaints. Just curious. I'm considering using 2 mounts on it so mor interested in an additional spacer, but I could 3D print one. If they are not real expensive I'd rather save the time.
    For parts queries, best to speak to the people at the Store directly: http://support.openbuilds.com/support/home
    And yes, ER11 is somewhat based on familiar models, but with a lot of re-engineered components where it matters. Genuine NSK angular contact bearings, compared to plain ball-bearings in the others, ER11 precision collet tapers and nuts (compared to "oem" collets usually only available in one size, and being a cast part, rarely runs true). Balanced rotors and collet nuts, custom power cable, and many other little pieces of secret sauce inside
  5. Giarc
    Now if only I could buy one here in the U.S.:)
    Rick 2.0 likes this.
    Giarc and stuart wallace like this.
  7. JayJ
    JayJ New
    Is there a way to buy a 220 volt version?
    You can buy them with a machine bundle only: "Due to popular demand, the RoutER11 is available as an option on machine bundles only."
