blackbox with external drivers?
Discussion in 'Controller Boards' started by baum, May 17, 2021.
  1. baum
    baum New
    So i have one of the original bb's (the one where you had to assemble it). I was wondering so I can use a "hi-torque" stepper with higher voltage can i grab a step/dir from the bb? I would be using 4 drivers (2-y, 1-x, 1-z).
    The signals are available (and labelled) on the Pin headers between the boards, so if you want to solder to those, you can pick it up from there.
  3. baum
    baum New
    Thanks, Any chance can you send a pic of it?
    It's printed on the PCB:
    Oppozith and baum like this.
  5. Mohamma393
    Hi
    A know this is too old but just feel better to ask here not in new post, sorry if you don’t prefer this
    I can see header on the the BB32 but without detail on them like BBx4
    not sure if they are same arrangement or how to know each one for what
    i need to connect external driver for Y only
    #5 Mohamma393, Sep 29, 2023
  6. Mohamma393
  7. David the swarfer
    have you looked at the other side of the board?
  8. Mohamma393
    what i see is they are same but I know I’m not smart enough
  9. David the swarfer
    BETWEEN the two boards, mine is labelled there
  10. Mohamma393
    Ohh thank you , will see now :D
  11. Mohamma393
    Just sent to electronic guy and soldered
    Then for driver side (DQ542ma maybe)
    Will just connect step to PUL , direction to DIR
    And all negatives to -v in PSU , is that correct?
    same in photo here but without enable
    this related to xprov3
  12. Mohamma393
    And is better to parallel signals for 2 drivers, use one bigger driver for Y1Y2 motors or just use original BB32 driver for Y1 motor and extrnal one for Y2 motor
  13. David the swarfer
    no, do not connect the PSU ground to the signal ground
    you need 3 wires from the controller to the pulse and direction inputs on the driver
    GND ,DIR, PUL
    Mohamma393 likes this.
  14. Mohamma393
    So pul- and dir- go to ANY ground in the blackbox ?
  15. David the swarfer
    to the signal ground in that same set of pins, NOT the ground that the 24v psu uses
  16. Mohamma393
    I'm l sorry for my dumb questions
    I can solder to ground pin, i cant use for example door ground, limit switch/ toolhead ground?
    Really appreciate your help
  17. David the swarfer
    i cant read the labels in your photo, too small. but at least one of those pins in a signal ground, use that.
    I don't know if the BBx32 shares an internal ground between the signals and 24v psu, I havn't seen the circuit diagram yet
    maybe @Peter Van Der Walt can tell us?
    Yes there are GND pins in the interconnect.
  19. Mohamma393
    Thank you @Peter Van Der Walt @David the swarfer
    Yes i can see clearly GND pin above X DIR
    will solder wire to it
    Just thought i can use any GND on the BB
    Past week think to keep the new controller in a storage cabinet, really appreciate your help
  20. Oscar Mejia
    I'm going to attempt to do the same connection, a BB4x and 4 external drivers controlling 4 stepperonline close loop motors.
    Can anyone report success on a similar scenario?
    Tks!
  21. Mohamma393
    Just connected everything, y1&y2 move very quite and smoothly but the moving only one direction which is negative direction
    Turned off then on, they moved both directions for 20 seconds then again only one direction
    stepper drivers DM542t from stepperonline
    signals side
    Set to 5v (3.3-5v)
    step pin header from BB ——-> PUL+
    Dir pin header from BB ———>. DIR+
    Gnd pin header from BB ——— PUL- & DIR-
    motor and supply side
    A+ yellow
    A- green
    B+ blue
    B- red
    All openbuilds motors
    +VDC ————> v+ psu
    Gnd ————> v- psu
    I checked signal from BB to driver with multimeter all good connections
  22. Mohamma393
  23. Peter Van Der Walt
    If both act the same, its the input signals. Make sure your drivers support 3.3v signals, some of the more budget drivers needs 5V signals
  24. Mohamma393
    Yes both exactly same act
    manual said 3.3-5v
  25. Peter Van Der Walt
    Not according to the datasheet you just posted.
    Use a High speed Level Shifter
  26. David the swarfer
    according to that inputs are 4.5 to 5.5v, so 3.3 probably not enough to drive the direction signal but is driving the step signal.
    You will need a buffer to translate the 3.3v signals to 5v TTL signals, maybe a 74hct04 hex inverter or 74hct125 or 139 buffer driver chips.
    I would not use one of those little bidirectional 4 or 5 way translators with the mosfets, they cannot handle the high frequency step rates.
  27. Mohamma393
    Here 3.3-5 haha that’s why I bought it, will have a look at level shifter , thank you Peter
  28. Mohamma393
    Ok thank so much
    Will search abou what you said
  29. Peter Van Der Walt
  30. David the swarfer
    that is exactly the thing that will fail at high step rates (-: at least, I could not drive RGB LED strings through one of those at 800kHz.
    so, it all depends on real step rates I guess, an dhow well it can drive ~20ma into an LED
    *My* DQ542 drivers are quite happy on 3.3v direct from an ESP32, short wires and so on, maybe I just got lucky.
