Controller Board
Discussion in 'Controller Boards' started by Atif Ali, May 23, 2021.
  1. Atif Ali
    Atif Ali New
    Can we replace Brain Board in Black Box.
    If it is possible then where from we can buy?
    Because I am facing problem to connect with USB port before today it was work well now it's showing on serial console.
    I also tried to flash it but failed.
    [18:40:01] [ usb ports ] Detected a change in available ports: [COM3]
    [18:40:14] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [18:40:14] [ connect ] Checking for firmware on COM3
    [18:40:14] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [18:40:14] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [18:40:15] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [18:40:17] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM3
    [18:40:18] [ disconnect ] PORT INFO: Port closed
  2. sharmstr
  3. Atif Ali
    Atif Ali New
    After few days BLACK BOX could not connect with USB Port due to Brain Board problems.
    Now it's under Warranty period.
    How can I claim it.
    2nd option is if I want to buy BRAIN BOARD separately is it possible.
    Please help me.
  4. Atif Ali
    Atif Ali New
    I have tried but failed. I removed all wiring connections from Black Box and tired to connect it with USB port but failed.
    Now what u suggest for me.
    Refer to docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for the complete procedure. The fact that you posted here, on the forum, tells me you need to go back and work through that list once more :), you missed a step
    But one of many steps in docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation]
  6. Atif Ali
    Atif Ali New
    Serial Console is showing.
    Atif Ali, Yesterday at 6:38 PM
    This all was happened due to short circuit in limit switch.
    Now I adopted all institutions from topic 6.3.1. To 6.3.6 but failed to reconnect with usb port how can I resolve it.
    If you caused a short, its unfortunately dead.
    Read the warnings in docs.openbuilds.com and order a replacement from http://support.openbuilds.com/support/home
    Sorry to hear that, but next time (every time), double check wiring before powering on anything.
  8. Atif Ali
    Atif Ali New
    Are you sure it's dead.
    Can you read error again.
    I think its my opinion that there is short circuit in limits switch.
    May be i should wrong please check it again.
  9. Atif Ali
    Atif Ali New
    If it is dead then why it's closing usb port as per error report.
    If you shorted V+ to gnd at the limits in particular, you killed the MCU. The USB chip is seperate. Thus the big warnings on the Limit switch wiring pages in the docs too.
    I am one of the lead designers of BlackBox. And developer of CONTROL. And wrote the documentation. I know what the error means, if you worked through the list in the docs, and it doesn't come right, it is damaged.
    You did work through the FAQ page right? it covers all the non-dead bases
  11. Atif Ali
    Atif Ali New
    Respected sir I know who r u.
    Therefore I requested to read error and suggest suitable solution for me.
    According to error what happened with brain board.
  12. Atif Ali
    Atif Ali New
    In this situation is it possible I connect ardiuno uno with stepper driver board and operate it with open build motion control.
    Is it possible.
    Already answered above:
    Theoretically yes (pinouts is labelled on board) , but, as also mentioned before, rather speak to http://support.openbuilds.com/support/home and you'll be able to buy replacement parts or complete Blackbox from them
