Adding Limit switches
Discussion in 'General Talk' started by BeeAMaker, May 25, 2021.
  1. BeeAMaker
    BeeAMaker Well-Known
    Is it possible to add a second set of limit switches to the X and Y on the Lead1010?
    My theory is to tie them in parallel to the existing homing limits. That way if I miss judge distance I don't manually move the X orY into it's extents, it stops before grinding the motors. :)
    (not that I do this or anything....)
    My X is slightly out of square with the Y so if I hit the extents, I have to re-square the X so I want to prevent hitting the extents.
    If you have Xtension limits, then yes,
    V+ on BlackBox to V+ on first switch to V+ on second switch
    GND on BlackBox to GND on first switch to GND on second switch
    SIG on BlackBox to SIG on first switch to SIG on second switch
    Rplutter likes this.
  3. BeeAMaker
    Thanks, just found it in the docs also.
    Rplutter and Peter Van Der Walt like this.
