IOT Switching Relay Power Strip
Discussion in 'General Talk' started by JayJ, May 27, 2021.
  1. JayJ
    JayJ New
    Looking for a 220 volt version of this to use here in Germany. Not sure what I would even search for on amazon. I tried using the English words but that did not give me any results that were even close. Any suggestions?
  2. Rink
    Rink Well-Known
    I searched on amazon and also did not find anything in 220v, only 110v.
    Thx, rink.
    Nothing off the shelf we know off. A good electrician can build you a setup using an opto coupled relay driver and a contactor, but for liability reasons we cannot assist directly
  4. JayJ
    JayJ New
    Thanks. I think I came up with a solution lastnight. I have built something similar for my ambient lighting on my tv that turns on and off via a relay and a usb from the tv. Will see if I can apply the same here. I am assuming it is just a 5volt signal that is sent from the black box that could be used to activate a relay.
    As long as you dont try driving a relay coil directly. Signal is logic level, couple mA max. Can drive an Optocoupler
  6. JayJ
    JayJ New
    Using a small relay I can now control the router/spindle from the control software. Is there a way to have the tool start and stop automatically when I run?
    Your CAM application/post processor should add the commands to your Gcode file. What CAM are you using?
  8. JayJ
    JayJ New
    I use vCarve to create the files and then run them with Openbuilds control
  10. JayJ
    JayJ New
    Thanks for the help. Total success. Five dollar part and a 3d printed case has it working.
