Eck! started and just dug through!
Discussion in 'CNC Mills/Routers' started by Thomas Lamourine, Jun 3, 2021.
  1. JustinTime
    I use Fusion and SketchUp. Fusion is for 3D, which Sketchup sucks at royally. ALL my router projects are designed in SketchUp and the gcode is generated in SketchUcam, which David (the swarfer:)) is upgrading and maintaining. It works like a charm and if I have a question David answers it promptly.
    For what its worth, the same precious David maintains both SketchuCAM and the Fusion Post (; - so fighting over which is better is not an issue, you need David either way.
    His work on the Fusion post fixes bugs even Autodesk doesn't know or care to.
  3. Thomas Lamourine
    Yaya, I kinda noticed that! guess he's the MAN! anyway.. seeeemmmmmmsss..?? I got it all straight now! Though I just broke a bit as I forgot to "home 1st before going to zero :mad:, my own **** fault now that I should know better.
    thanks for ll the help!
