J TECH LASER (7w) WITH WORKBEE 1010
Discussion in 'Laser Cutters' started by Kilkenny, Jun 18, 2021.
  1. Kilkenny
    Kilkenny New
    I need some held.
    I completed the installation by following the instructions for the Lead 1010. Now in the GRBL Setting, there is no option to select Workbee 1010 with Laser module as it is possbile to do with the Lead 1010. Someone can help me to finalize the intallation, what I should do next?
    You can use the WORKBEE1010 profile, the "laser profile" just sets Laser Mode to Enabled for you (and has a little higher acceleration and feedrate, but you should anyway always assume profiles are conservative and spend some time tuning your machine for max performance):
    See gnea/grbl and gnea/grbl
    And read more about Laser Mode here: gnea/grbl and gnea/grbl
  3. Kilkenny
    Kilkenny New
    Thank you Perter for your held. I have no laser light and before I contact J Tech about this issue. Can you confirm that I did remove the right jumper in the Black Box see the pictures. Picture 1 before I removed the jumper and Picture 2 jumper removed. Also, $32 is enable.
    The jumper removal just stop the relay chattering. Unrelated to the actual laser circuit, its just to prevent the relay wearing out when you use the laser.
