High Z
Discussion in 'General Talk' started by Robert Drisaldi, Jun 22, 2021.
  1. Robert Drisaldi
    Good morning from Houston, Texas!
    I re-built my spoil-board based on John Wylie's design below: (Thanks for the design, John)
    T-slot Clamping Wasteboard On Dead Flat Worktop.
    The ONLY issue with this design is the loss of Z axis height. I needed to surface a 2 inch piece but my Z gantry assembly would not clear because of the new positioning of the spoil-board. Everything else about the design is genius.
    I'm concerned that if I add a high Z modification that I'll then have an issue with my smaller 2" bits reaching the material. Is this a valid concern? If so, would anyone have a suggestion to remedy?
    Thanks!
    With the High-Z your router position is still adjustable - move it lower for short bits, and up for longer bits. All good!
    Dennis Bansgopaul likes this.
  3. Robert-Lee
    Outstanding. Ordering it right now!
    The OpenBuilds team rocks. Thanks for always having an answer Peter
    You won't regret it (; that extra gantry beam does a LOT to increase the machine rigidity (;
  5. Robert-Lee
    I recently trammel my router. I guess I should do it again, once the high beam is installed?
  6. Robert-Lee
    Correct as you make major structural changes
  8. Robert-Lee
    Trammel? You probably knew what I meant!!
    :) Yes I did, tramming :)
