Minimum PC/laptop hardware requirements
Discussion in 'Control Software' started by GS76, Jun 24, 2021.
  1. GS76
    GS76 Well-Known
    I am running a Windows 10 laptop.
    Openbuilds Control software is excellent and so easy to use! Thank you.
    I am having trouble that OpenBuilds control software hangs a great deal!
    I believe it's due to insufficient RAM or SSD speed/space or I have too many memory-intensive applications loaded on the laptop!
    Anyway, I just wanted to know what the minimum PC/laptop hardware requirements are for the successful running of OpenBuilds control software.
    Oh, yes I do have a good USB cable. I have the following:
    USB 2.0 A/B Cable, Ferrite Chokes, 3 ft. | Tripp Lite
    Unless my USB ports and/or drivers are an issue.
    Thank you.
    Regards,
    Gary
    For us to comment on the specs of your computer, it would be helpful if you provide them :)
    There's no minimum specs for control, if the PC is old, its gonna be slow. Simple(ish) as that.
    But mostly: Try after a fresh reboot, make sure Graphics and Chipset drivers are up to date, and close any conflicting applications.
  3. GS76
    GS76 Well-Known
    Thank you for the rapid response.
    Please see my laptop specs, by running "systeminfo" command:
    Microsoft Windows [Version 10.0.19041.1052]
    (c) Microsoft Corporation. All rights reserved.
    C:\Users\garys>systeminfo
    Host Name: GARY-1976
    OS Name: Microsoft Windows 10 Home Single Language
    OS Version: 10.0.19041 N/A Build 19041
    OS Manufacturer: Microsoft Corporation
    OS Configuration: Standalone Workstation
    OS Build Type: Multiprocessor Free
    Registered Owner:
    Registered Organization: N/A
    Product ID: 00327-30487-34958-AAOEM
    Original Install Date: 2021/01/30, 11:18:14
    System Boot Time: 2021/06/19, 17:20:36
    System Manufacturer: HP
    System Model: HP 255 G5 Notebook PC
    System Type: x64-based PC
    Processor(s): 1 Processor(s) Installed.
    [01]: AMD64 Family 22 Model 48 Stepping 1 AuthenticAMD ~1800 Mhz
    BIOS Version: Insyde F.30, 2017/11/01
    Windows Directory: C:\WINDOWS
    System Directory: C:\WINDOWS\system32
    Boot Device: \Device\HarddiskVolume2
    System Locale: en-gb;English (United Kingdom)
    Input Locale: en-us;English (United States)
    Time Zone: (UTC+02:00) Harare, Pretoria
    Total Physical Memory: 3 551 MB
    Available Physical Memory: 490 MB
    Virtual Memory: Max Size: 13 662 MB
    Virtual Memory: Available: 5 592 MB
    Virtual Memory: In Use: 8 070 MB
    Page File Location(s): C:\pagefile.sys
    Domain: WORKGROUP
    Logon Server: \\GARY-1976
    Hotfix(s): 12 Hotfix(s) Installed.
    [01]: KB5003254
    [02]: KB4561600
    [03]: KB4577266
    [04]: KB4577586
    [05]: KB4580325
    [06]: KB4584229
    [07]: KB4586864
    [08]: KB4589212
    [09]: KB4593175
    [10]: KB4598481
    [11]: KB5003637
    [12]: KB5003503
    Network Card(s): 2 NIC(s) Installed.
    [01]: Realtek PCIe GbE Family Controller
    Connection Name: Ethernet
    Status: Media disconnected
    [02]: Intel(R) Dual Band Wireless-AC 3165
    Connection Name: WiFi
    DHCP Enabled: Yes
    DHCP Server: 10.0.0.254
    IP address(es)
    [01]: 10.0.0.105
    [02]: fe80::2878:698a:6b01:e102
    [03]: fd50:1d9:634f:1800:3428:580d:c1d5:87f8
    [04]: fd50:1d9:634f:1800:2878:698a:6b01:e102
    Hyper-V Requirements: VM Monitor Mode Extensions: Yes
    Virtualization Enabled In Firmware: No
    Second Level Address Translation: Yes
    Data Execution Prevention Available: Yes
  4. GS76
    GS76 Well-Known
    What could be possible conflicting applications that you know of?
    Only 490mb of free memory, something is hogging all your ram
    Only has 4Gb, but should still be able to load GCODE files up to around 800k-1mil lines with that
    Being a laptop, the onboard graphics may be a little slow - go to Troubleshooting tab > Application Diagnostics and disable the 3D viewer
    Everything that the manufacturer preinstalled for you - that you don't need. Check the startup applications and clean up the bloat. Stuff like trials of Office, several "HP utilities" running in the background, etc: See How to clean boot Windows 10 (and why you might want to) | Windows Central
    Windows itself comes with a bunch of useless stuff too: How to Easily Remove Bloatware From Windows 10.
  6. GS76
    GS76 Well-Known
    Hi Peter,
    Thank you for all the useful information.
    Much appreciated.
    Regards,
    Gary
