Fusion 360 Home addition Post Processor Installation
Discussion in 'CNC Mills/Routers' started by Randy, Jul 3, 2021.
  1. Randy
    Randy Journeyman
    Hi folks,
    Since the changes with 360 I can not install the post processor to get my Workbee working.
    I have tried to follow some of the youtube videos but none of the windows or the options ae the same in the Home edition.
    Could someone do a tutorial on how to get a mill up and running on the Home edition please.
    I would really appreciate it.
    Thank you in advance,
    Randy
    #1 Randy, Jul 3, 2021
  2. Alex Chambers
    What controller are you using, and therefore which post processor?
  3. Randy
    Randy Journeyman
    I am using the blackbox and the download that I found here for the post processer. I am lost with this home version.
  4. Alex Chambers
  5. Randy
    Randy Journeyman
    The screens in the tutorial are not the same as those in the home user edition. I tried using the one you posted. The set up screen is completely different . When I get back I will post some screen shots.
    #5 Randy, Jul 3, 2021
  6. Alex Chambers
    By "home user edition" I assume you mean the "personal use license". All you need to do is find the post processor folder for Fusion and copy the post processor into it. Will post some suggestions about where it is likely to be (on a Windows PC) when I get back to my PC.
    PS, Autodesk keep changing the appearance of Fusion, but the appearance of the personal use license version is exactly the same as the paid for version.
  7. Alex Chambers
    See the pic below - when you have downloaded the Openbuilds post processor, copy it into the directory shown, and select "Use Personal Post Library"
  8. Randy
    Randy Journeyman
    Ok here are some screen shots. No matter what I do I can not get it to work.
  9. Randy
    Randy Journeyman
    These two screens do not exist the same in the home use licence.
  10. Randy
    Randy Journeyman
    Sorry Alex I don’t have those this version. I don’t know what they have done but nothing works.
  11. David the swarfer
    put the post file in any folder you like, say c:\users\yourname\documents
    click little square with the ... in it rather than open the menu
    open your documents folder
    click 'ok'
    now, the available posts will be listed and you can select the post file, (I have a few, you will have only the one you downloaded, see my video later.)
    This selection will remain selected unless you change it. You may need to reselect for each new drawing, but I doubt it.
    #11 David the swarfer, Jul 4, 2021
  12. David the swarfer
    In essence, you put the post file somewhere, then you tell Fusion where it is.
    The somewhere can be one of fusions defined and preferred places like the 'personal post library' folder indicated previously, or it can be ANY folder that you know how to find, Desktop, My Documents, Downloads, some mapped network drive if you have a server, etc etc.
    Here is how, watch the video
  13. Randy
    Randy Journeyman
    Well this is just weird. Why am I not getting the same screen as you are. I am going to reinstall this program and try all this again.
    Thanks for the help.
  14. Randy
    Randy Journeyman
    Yes I did all that. My issue is that I am Not getting the same screen that you folks are showing me so I can’t follow you or do what your asking me to. This is a legit program from Autodesk and I have installed it twice now. I am really getting fed up with this. If I could I would just buy a program that works.
  15. Randy
    Randy Journeyman
    Ok, I bought a subscription to the program and now I am able set things up. What a royal pain that was.
    The Canadian version must be different than the American. It shouldn’t be but the screens are completely different from what you folks are showing me. When I go to settings I get this page.
    Anyway, stay tuned for more questions.
    Thank you folks,
    Randy
  16. sharmstr
    Looks like you got to that screen via the setup menu. That's why the screen looks different. Go to the Actions menu and click on Post Process
  17. Randy
    Randy Journeyman
    Ok, did that. Here is what I get.
  18. JustinTime
    @Randy, I live in Southern Ontario and I followed David the swarfer's instructions and got all the same screens that he shows.
  19. Randy
    Randy Journeyman
    Well then I don’t know what is going on. Frig.
  20. JustinTime
    I hate to tell you but it looks like you didn't follow the instructions in the video judging from the pictures you posted above. It looks like you DIDN'T right click on the first 'Setups' and then left clicked on the 'New Setup'. Once you have the new Setup right clicking on it opens the dropdown menu David is talking about.
  21. Randy
    Randy Journeyman
    I did. I will try it again.
  22. Randy
    Randy Journeyman
    Well that did nothing. I sent an email to Autodesk. Will see what they have to say. Thank you
  23. Rob Taylor
    Ok I haven't really been following the thread, but if all you're trying to do is install a custom post, wouldn't one of these three buttons allow you to find it in the folder you downloaded it to?
    Seems like it to me, anyway. I'm assuming the dots would be the one- dropdown allows selection of stuff it knows is there, pencil is edit what you currently have selected.
    Again, I haven't looked into it at all, just... That's how computer UIs are supposed to work.
    Also, the original screens that Alex showed you-
    - are literally from when you've finished your CAM and hit "Post-Process". It's like, the final step. You can't do it without actually having at least one operation in your setup.
  24. Randy
    Randy Journeyman
    Yes,I have done that.
  25. Rob Taylor
    This would suggest otherwise:
    From the looks of all of these screens, the post is actually installed, it just has nothing to work on.
  26. Randy
    Randy Journeyman
    Ok thanks. I need to take a break. I have beed working on this since 2 this morning. I am going to find someone to log on my system and have a look at what is going on.
  27. Alex Chambers
    @Randy I can do that if you have Team Viewer.
  28. Randy
    Randy Journeyman
    Yes. Can we do it a little later? I really need a break for a couple hours.
  29. Alex Chambers
    I'm UK based, so its nearly my bedtime :sleepy:.
    Should be able to find time tomorrow - I guess that would be afternoon your time if you are US based?
  30. Randy
    Randy Journeyman
    Ok sounds good Alex thanks. I am in BC Canada. Anytime tomorrow then. I am usually up by 3 in the morning Pacific.
