any tutorial on Openbuilds cam-gcode generator ?
Discussion in 'General Talk' started by Tom Bellfoy, Mar 1, 2021.
  1. Tom Bellfoy
    Tom Bellfoy Well-Known
    I have been reading a lot on how to operate my Openbuilds lead 1010 machine and since I'm just starting out
    I have a number of concerns.
    1. Is there a tutorial on youtube on using the Openbuilds cam-gcode generator ?
    2. I have the soft and hard limits working good, I have calibrated my 1010 and it measures correctly, I have my Openbuilds XYZ probe working correctly so I can start a job, now its time to surface the spoil board using the wizard, How can I get the machine to start the surfacing where I can do most of the board after I bring the cutter to home ?
    1) Just the Hello World video: docs:blackbox:hello-world [OpenBuilds Documentation]
    It's as easy as:
    - Load file
    - Select some lines and add them to a toolpath
    - Set parameters
    - Click Generate GCODE
    2) You setzero on the bottom left corner of where you want to start, and enter the appropriate dimensions from there, in the wizard
    Rick 2.0 likes this.
  3. Tom Bellfoy
    I had the spoilboard surfacing started ok but later I started having trouble with the machine shutting down . The shut down message was as follows:
    error 9
    G-code locked out during alarm state
    The error may be just a symptom of an earlier event
    alarm 1 - hard limit triggered. machine position is likely lost due to shutdown
    - seems every time I get near the first pass It shuts down and I get the same message , however machine not even close to setting off the limit switches
  4. Alex Chambers
  5. Tom Bellfoy
    Alex: Thank you for your reply which led me to do some testing as to where the interference was discovered.
    It is now working well.
    Here are some facts:
    -I have the Openbuilds dust boot but did not use it today while I was setting up to surface the spoil board and this created a lot of MDF dust
    After three or four rows while creating the dust this is where the machine would shut down with the error code.
    Frustrated I went to the forum where you replied about the static/electrical interference and I read up on the EMI in the documentation.
    I went back into my shop and did this:
    - I vacuumed the dust particles on the CNC
    - I ran the spoilboard job again while surfacing tool was lifted (high Z) and router turned off, all good, no alarm
    - after 5 minutes I turned on the router still not touching or cutting spoil board, all good
    - after another 5 minutes I turned on the vacuum and let it run for another five minutes, all good
    So through process of elimination I have determined the MDF dust was creating the static condition which in turn put my CNC
    machine in alarm error # 9.
    Now all I have to remember is to use the dust boot especially when I'm working with MDF.
    I learned a lot today
  6. Alex Chambers
    Be aware that the dust and air rushing through your vac hose can build up static which can have a similar effect. Hopefully your problem is solved, but if it happens again with the vacuum running the next step is to earth the vac hose - bare copper wire along the inside and connect to mains earth at the vac end.
  7. Robert Drisaldi
    As a new CNC'r myself, I highly recommend getting V-Carve Pro or V-Carve Desktop, by Vectric. A fantastic program and easy to learn. Plus, there are tons of tutorials available on youtube
  8. Tom Bellfoy
    Alex:
    Another good point, I will pick up some bare copper wire. thx.
    Robert:
    Good point, I had decided to order the Vcarve Pro software but wanted to make sure I could use it with Openbuilds Lead 1010. Its costly software but we can do so much with it. I;ve been watching a few of Mark Lindsay,s tutorials on Vcarve.
    Tom
    Robert Drisaldi likes this.
  9. Robert Drisaldi
    Mark is the dude to follow
  10. Cool Monkey
    Tom did you ever get a reply? Im looking for the same thing.
  12. Cool Monkey
