OpenBuilds CAM Software
Discussion in 'CAM' started by Mark Carew, Oct 8, 2018.
  1. JustinTime
    Having it raised and with a 3/8" border will be a taunting task, at best. I opened the .dxf file in SketchUp with no problems and checked it out. On a 8x8 piece of wood the max bit diameter you can use is 1/16" and maybe even smaller. To pocket out all the material you don't want with a 1/16" bit is a chore since you'll have to have the bit do an overlap when pocketing or the final result will look like grooves and not flat.
    In this specific design, the bigger the piece you use the easier it will be to do.
  2. Sophabean
    Sophabean New
    OK, back to the drawing board. Thankyou very much for your help.
    • Opened your file in QCAD
    • Converted everything to Polylines using the Draw > Polylines from Selection command
    • Took that into CAM
    • Added a square as a border around (as a boundary, to pocket the negative space)
    • Selected-all (Ctrl+A)
    • Added to a new toolpath, pocket, apply:
    Just learn to cleanup DXFs, its a valuable skill and takes no time at all :)
    Attached the fixed DXF and OpenBuildsCAM Workspace Export (You need to modify feedrates, tool diameters, etc to suit your actual job)
    As mentioned earlier above:
    That's all I did here, converted it to DXF R14 Polyline format for you, didn't even need any other cleanup.
    Giarc and Gary Caruso like this.
  4. samuel66
    samuel66 New
    bonjour je suis débutant dans le milieu de la cnc.je voudrai acheter une Lead 1010 mais je sais pas quel logiciel prendre . Pouvez vous m éclairer a ce sujet merci
    (moderator added translation: this is an English forum only):
    hello I'm a beginner in the middle of the cnc.je would like to buy a Lead 1010 but I do not know what software to take. Can you explain to me this subject thank you
    #244 samuel66, Oct 7, 2021
  6. Joel Gamboa
    hi, i a having similar problem, actual cutting is smaller off by inch, i noticed the error follows the size, larger design the worst, and its scale issue as the diff is distributed to both x,y axis
    Calibrate your Steps Per Mm:
    WilliamK and David the swarfer like this.
  8. GS76
    GS76 Well-Known
    Hi @Peter Van Der Walt and @Mark Carew ,
    Just congrats on the OpenBuilds CAM software!!
    I just tested it, and it is fantastic... easy to use. It works exactly as expected.
    Well done, and thank you for such a tool.
    Regards,
    GS76
  9. WilliamK
    WilliamK New
    Worked great. The instructions were very well written and programmed.
  10. KEN MACDONALD
    On setting up it has a drop down list of machines. My Ox CNC is not listed. Should I use WORKBEE?
    Ken
    Pick nearest then scroll down and do any specifics like custom sizes etc
  12. Arthur J Downey
    I really like the Gcode Generator and it's been working well, but I'm wondering if there are plans to support 3d greyscale conversions or if the gcode generator will be 2d only.
    Thanks!
    For more advanced work we recommend Vectric Products - OpenBuilds Part Store
  14. Eirelo
    Eirelo New
    Is OpenBuilds CAM work with Genmitsu PROVerXL 4030 ?
    I have tried to set it up but there is no option for this machine can I select another one?
    The presets just fills in the form below it for you. For a custom machine, scroll down and enter details your machine needs. Tech support for software is provided for our customers, for 3rd party machines you are welcome to use CAM, but we do not provide a lot of technical support
  16. Eirelo
    Eirelo New
    I am not sure to understand part 3 "Select your Machine" I should select what?
    Doesn't matter - as it just fills in some details lower down (in section 5): What matters is what is in section 5. Machine type really just sets the size
    Eirelo likes this.
  18. Eirelo
    Eirelo New
    Thank a lot
  19. Matthew187m
    I am having a problem with Openbuild cam. I am selecting my vectors which are open. I choose cnc vector no offset. it builds the toolpath for me.but the problem is it does the vector correctly on the first pass.when its time to retract and go to the next point it does not.instead it remains at cutting depth and makes a straight line cut all the way to the beginning of the vector. which cuts through the first cut.theres no lead in and lead out option. Im a cnc programmer for 10 years. I dont want to adjust the gcode to fix a problem in a software because if im working with many open vectors that is too much time consuming.Please can you give me a solution ASAP. Its urgent.I attached a picture where you can see the line.
  20. Peter Van Der Walt
  21. TomTom Mick
    Any idea when I import a DXF it throws it way off the grid? I have to zoom way out to grab it and put on the table grid for my tool path?
  22. Peter Van Der Walt
  23. TomTom Mick
  24. GS76
    GS76 Well-Known
    I have created a program to mill out a small circle at a small depth. See attached.
    I see it has yet to create any G2 commands on G1 commands, as the circle is broken up into polylines.
    I am just not used to G-code being generated this way. I am using the BlackBox X32 controller. Is this the optimal G-code for a circle for this type of full circle?
    Thank you again for the great CAM software, controller software and controller.
    Your support and product is impeccable.
  25. Peter Van Der Walt
    Our free and beginner orientated CAM is super simple and doesn't bother with Arcs. If you need proper Arcs, use a more advanced CAM
  26. GS76
    GS76 Well-Known
    I have included a workspace and the g-code generated from Openbuilds CAM.
    I understand it has created a G1 g-code due to the polylines. But, I do not understand why there is an "S1000" between the polyline lines of the g-code.
    Am I missing something?
    Thank you for such easy-to-use software.
  27. Peter Van Der Walt
    Spindle Speed = 1000. If $30=1000 in Grbl Settings, the S1000 = 100% speed. Not needed unless you want spindle control, can be done once, or each line, etc
    Don't overthink it. Use a CAM, as a CAM. Run the test jobs. In time you'll learn more about Gcode, but honestly - no one hand writes gcode, and we aren't going to be able to keep up the replies on this. OpenBuildsCAM is a proven CAM and works just FINE. Use it as is, or use something else. Thanks.
  28. GS76
    GS76 Well-Known
    Thank you for the explanation.
  29. Noob404
    Noob404 New
    Hi, I am very new to this and I am attempting to cut a panel. I started with an open vector error in cam builds but after scaling everything down and just concentrating on the outside panel I eventually got it to work. My main issue now is to generate G-code. Once I import my DXF file to the cam program and create a tool path, it looks like everything is fine but then when I try to generate G-code it only generates the basic toolpath without my design. Any advice on what I am doing wrong.
  30. Peter Van Der Walt
    Going to need to see the Workspace Export (OBC) from File > Export Workspace to help you see what you have done to see what might be wrong
    Scaling might not close an open vector. Give CAM good clean and correct CAD files docs:software:file-errors [OpenBuilds Documentation]
