Hello, black box uncontrollable movement
Discussion in 'General Talk' started by Kidd-c, Jul 31, 2021.
  1. Kidd-c
    Kidd-c New
    I'm French sorry for the G. translation.
    I have a problem with workbee 1500 and the blackbox.
    The machine no longer follows the grbl routes.
    My grbl code is good (tested on foam no problem) (makita router at least 1)
    - Uncontrollable movement -
    4 failed attempts on wood with 3mm pocket 3d passes, uncontrollable movement and the cutter plunges several mm -6mm> 9mm (makita router half power 4).
    - EMI -
    I have grounded the makita router.
    I kept all low voltage wires as far apart as possible.
    I grounded the chassis.
    Questions :
    -I must earth the shielded wires of the 4 motors?
    -I don't know if the grbl code changes due to the EMI?
    -I must earth each cart?
    -Change my earth wire with an armored one?
    I cannot find a solution for the uncontrollable movements.
    Thank you
    The straight line runaways do look like EMI: see docs:blackbox:faq-emi [OpenBuilds Documentation]
    But do rule out as well:
    - acceleration and max rate not too high? Could cause stalling during rapid moves. In particular if you do not have OpenBuilds motors.
    - mechanical: shaft coupler setscrews tight, etc
  4. Kidd-c
    Kidd-c New
    sorry for the translation
    Hello, the displacement is 1400m / min - 500m / min in diving - pass of 3mm.
    nema23 motor, mechanical drive, I will ground everything.
    - If I change the speed while working with the switch function on the OB command 1400m / min to 1600m / min, is there a problem?
    - The motor x1 and x2 not the same voltage, it seems to me to have adjusted the screws x1 x2 on the BBox differently. possible problem?
    - Can openbuild 24v circular LED lighting can magnetize the router clamp. isolate the led lighting of the clamp?
    I'm looking for all the leads thank you
