y axix step per millimeter
Discussion in 'Controller Boards' started by juujjjuuuu, Aug 10, 2021.
  1. juujjjuuuu
    Hi
    I there a way to ajuste step per millimeter independently for y motors? I have a millimeter off only on the right side of the machine (on 40 inchs travel)
    I have a LEAD cnc with blackbox.
    Its more likely mechanical...
    You cannot calibrate individually.
  3. Christian James
    Christian James Journeyman
    Shut off the power supply then turn the flexible coupling (or lead screw) on the right side by about 1/8th of a turn and check again.
