flashing yellow light
Discussion in 'General Talk' started by robert christensen, Sep 19, 2021.
  1. robert christensen
    I want to put a safety light out side my shop door when i start my plasma table can i wire this to the black box? so it starts when i start a program
  2. robert christensen
    2nd question ... which torch holder works best with open builds ?
    You can wire a 24v light to the Coolant output and setup your CAM to add M8 at the start, M9 at the end.
    See docs:blackbox:connect-coolant [OpenBuilds Documentation]
  4. robert christensen
    thanks for the info works good, so onto next question, using blackbox and lightburn with an endurance 10 watt laser, my home has always been lower left, today when i turned it on and wrote BOB it did not go from left to right it wrote it up and down , when i tried to change the axis it sent back words but again up and down not right to left. I'm i missing something in blackbox to change x to y and y to x ?
    Are you sure you wired it all up right? Sounds like you wired X to Y and vice versa
