Y2 Redlight
Discussion in 'Controller Boards' started by Fredrik Carlsson, Oct 4, 2021.
  1. Fredrik Carlsson
    Hey!
    I have done some cutting with my Openbuilds controller today. Suddenly when i go to jog the machine i notice only one Y motor is turning. I check the openbuilds controller and see that the red light is on over the Y2 motor.
    I turn off the blackbox controller in hope of the fault disappearing but it dosent. I try changing motors while the controller is off but nothing changes. I switch motors and cables but the fault comes in directly when i plug in the motor. Same if i change motors and cables.
    Tried letting it cool down, turn down voltage, checked powersupply.
    Everything sits in a garage wich is 12 degrees celsius.
    See docs:blackbox:currentadjustment [OpenBuilds Documentation] for a description of the causes that trigger the Fault monitor and turn on the LED
  3. Fredrik Carlsson
    Get in touch with the store via Support for further assistance
  5. Dave0911
    Dave0911 New
  6. Dave0911
    Dave0911 New
    Hello Frederik, did you get this issue sorted out? I too have the same thing happening.
    Check out
  8. Dave0911
    Dave0911 New
    Thank you Peter
