DIY Vacuum Hold Down table
Discussion in 'Other Builds' started by Mike Campbell, Oct 3, 2021.
  1. Mike Campbell
    Mike Campbell Well-Known
    Mike Campbell published a new build:
  2. Mark Carew
    Very nice Mike! Having a vac table like this is such a game changer when setting up projects. Thanks for sharing
  3. Rink
    Rink Well-Known
    Good afternoon.
    Would a vacuum pump work?
    Thx, rink.
  4. Rink
    Rink Well-Known
    Good evening.
    It looks like you have another surface on top of your plenum grid board. Is that MDF? Did you shave off the surface on each side to help with the vacuum?
    Also, would a vacuum pump work well with this setup, in place of the shop vac?
    Thx, rink.
