help with homing on openbuild
Discussion in 'OpenBuilds Forum Help' started by bryan robbins, Nov 10, 2021.
  1. bryan robbins
    hi i have been using easel for making up signs ect it has been going well for weeks now
    this morning it wouldnt move and says it needs to be homed
    ive gone into openbuild and connected fine then tried homing it lifted up the router and kept banging the top
    then it came up with an error access denied ive restarted everything but alas it hasnt help please if you can get me back on my journey i would appreciate it thank you in advance
    Both indicate a problem with Limit switch wiring, first - by not seeing the signal, second, by shorting V+ to GND and thus shutting down the USB port. Check your switch wiring against docs.openbuilds.com/blackbox, and use the Troubleshooting tab in CONTROL to test
  3. bryan robbins
    thank you for your swift reply im about to check through them today thanks again
    bryan robbins
