ER collet question
Discussion in 'CNC Mills/Routers' started by Torin3, Nov 10, 2021.
  1. Torin3
    Torin3 Well-Known
    Just a quick question here. I'm planning on making a pocket board for my ER collets. I'm limited on horizontal spaces and was thinking it would be convenient if I could mount it on a wall. The easy way to do it would be to mill a pocket for each collet with a stepped down diameter at the base and epoxy a magnet in the base.
    Any issues with the fact this will magnetize the collets?
  2. Christian James
    Christian James Journeyman
    Swarf getting in the collet slits wouldn't be desirable and annoying to clean properly
    Peter Van Der Walt and Torin3 like this.
  3. Torin3
    Torin3 Well-Known
    Point well taken. This system though will likely be exclusively wood/plastic. I currently have no plans for metal, as I have an old Index Vertical 40 (1943 vintage) knee mill if I need to mill metal.
    Also, thanks to a previous boss, I'm kind of obsessive about cleaning ER collets when I take them out of the spindle. Blowing out with an air line at a minimum.
    I couldn't think of a major problem, but better safe than sorry.
  4. Christian James
    Yes, I assumed you were talking lathe or milling, metalworking use. Can you not do what you suggested, but add a retaining strip across the front to stop them falling forward?
  5. Torin3
    Torin3 Well-Known
    Finished the holder.
