Trouble wiring AMB 1400 FME-P DI to Black Box
Discussion in 'General Electronics' started by Ferdy de Smet, Dec 7, 2021.
  1. Ferdy de Smet
    Hi there!
    Just finished building my first CNC, a Rat Rig Killerbee 1510. At the final stage of the build I wanted to fire up my AMB 1400 and noticed it's not running at full speed. This is the setup:
    I wired the white and green directly to the Black Box on the 'Toolhead'. White on the GND and green on the 0-10V. The brown cable is wired directly to the 24V power supply.
    In the software the min RPM is set to 3.500 and max RPM to 25.000.
    Who can help me out?
  2. sharmstr
  3. Ferdy de Smet
    Not yet, I lent my multimeter to a friend. I'll get it back tomorrow if all goes well. I did play with the fine tuning but nothing resulted in a different spindle speed..
    Reread the Grbl Wiki too. Min RPM changes your scale. Is 0v=off or is 0v=3500rpm. You are telling Grbl to assume the latter.
    Also make sure to send the correct S values with M3
    M3S25000 for example (should output 10v after calibration) = 100%
    Ferdy de Smet and sharmstr like this.
  5. Ferdy de Smet
    I think it works now, thanks for your help!
