Iot Relay
Discussion in 'General Talk' started by John Raney, Dec 18, 2021.
  1. John Raney
    I bought an Iot relay through openbuilds. The switch seems to be intermittent. It goes on and off on its own. Should I try to fix it or should I return it for a replacement when they come in stock in the first quarter or should I send it in for repair
    John Raney
    Check your control wiring first. They are quite bulletproof, more likely a wiring issue. Loose terminal, or the like
  3. John Raney
    thanks will do
