Save a g38.2 log file
Discussion in 'Control Software' started by afinador, Dec 31, 2021.
  1. afinador
    afinador New
    I am quite illiterate in programming.
    But I had an idea of using a cnc apparatus that, through a touch probe, would measure the height and depth of the keys on a piano, using the G code
    I would only have two axes, in a very simple mechanical design.
    I have experience with mach3 where I use the M40 to save a log file (I need to take this data to excel which will calculate the amount to be changed on the keyboard later).
    So I ask:
    Is there no way for this in GRBL? ie save a log file on an sd card g38.2 results?
    I would like to use an offline controller...
    What does it take for this?
    Hire a programmer to change GRBL or make new code?
    A happy New Year!
    GRBL already does report the positions after a Probe, as you are writing your own interface code, see Grbl v1.1 Interface · gnea/grbl Wiki
    You can just log the results each time a "[PRB..." string arrives, simple text parsing to get the values
    afinador likes this.
  3. David the swarfer
    you can do a plugin for bCNC in python to do this for you
  4. afinador
    afinador New
    Thank you very much.
    I will investigate how to use this.
    Happy New Year!
