Flange bearing on x axis...
Discussion in 'General Talk' started by OICITNOW, Dec 31, 2021.
  1. OICITNOW
    OICITNOW New
    After resurfacing my spoilboard on my lead 1515 and doing maintenance items I stepped to the back of my machine observing the lead screw on the x axis when i noticed something riding on the lead screw.
    After a closer look it appears that the bearing part of the flange bearing has seperated from the flange itself breaking away from it.My machine is less than a year old and ive only run it about 8 hours total time.
    Defective part? Anyone else have this happen? Possible causes? Seems impossible to me.
  3. OICITNOW
    OICITNOW New
    I appreciate that, but for the price of the bearing Ill just replace it. Just wandering what caused it.
  4. Alex Chambers
    Your leadscrews will vibrate, and that will be absorbed by the bearing - it's like hitting the bearing with a very small hammer hundreds of times a second. Better that the bearing eventually fails than the plates wearing.
  5. OICITNOW
    OICITNOW New
    Makes sense.
    Thank you.
  6. Rick 2.0
    Over-tensioning the lead screw will also do it. Really should be using thrust bearings in these systems.
  7. Alex Chambers
