Z Axis not homing at the right height
Discussion in 'CNC Mills/Routers' started by Ciaran Burns, Jan 7, 2022.
  1. Ciaran Burns
    Hi all,
    Am new here, started a new job recently and have only been CNCing for 3-4 months so have rookie knowledge. However, I have been using the Workbee V2.1 for all this time and there have been a few problems along the way but none like this one.
    I was probing my work 0 using a touch probe which seemed to work until I hit go to work XYZ zero. The machine at that point went straight down into the bed and clipped the material along the way I then hit the E stop. I tried to home the axis after removing the material from the bed and the Z home is nowhere near where it usually is when homing it.
    As I did not have any input in setting this machine up myself I am at a dead end, every time I press home Z it seems to come lower and lower so am scared to press anymore times.
    Any help would be appreciated, Thank you in advance!
    Ciaran
  2. Alex Chambers
    First can you tell us what controller you use with your workbee?
    Ciaran Burns likes this.
  3. Ciaran Burns
    The controller I'm assuming is the web page I use for the machines commands and it looks like this:
  4. Alex Chambers
    Duet controller. Check the wiring to your Z homing switch, especially where it comes through the hole in the X gantry plate.
  5. Ciaran Burns
    Yes you were right! Thank you so much for replying so quickly, turns out one of the wires had completely frayed and melted away. My colleague and I have since fixed the issue.
    Sorry for the late reply.
    Will defo use this forum again thank you very much have a good weekend!
    Ciaran
  6. Alex Chambers
    @Ciaran Burns you would be amazed how often that comes up. Think about relocating the Z homing switch to the side of the Z C-beam and actuating it with a bracket mounted on the X gantry plate.
  7. Ciaran Burns
    Hi again Alex,
    Thank for the help last week it was great!
    I have just had a look at your speed and feeds graph and was wondering if the data for each material is the same for each size of bit?
    Also had a question about stepover, I have always had mine at 40% have read in other places that it should be lowered but yeah not really sure.
    Ciaran
  8. Alex Chambers
    That speeds and feeds table was created by the people at Carbide - I just did the metric conversion. It is for a 1/4"/6.35mm bit, but they don't even specify how many flutes. It's only a rough guide to get you started - with wood in particular each piece will be slightly different.
    Stepover depends on what you are doing - 40% would be fine for roughing - at the other extreme, if you were using a tapered ball nose bit for fine detail 8~10% would be more appropriate.
    Holley likes this.
  9. Holley
    Holley New
    Link to that Feeds/speeds table?
  10. Alex Chambers
