PnP 4 axis small/fast machine
Discussion in 'Other Builds' started by lewac, Jan 22, 2014.
  1. lewac
    lewac New
    lewac published a new build:
  2. The Dude
    The Dude Well-Known
    I'm interested in trying this but as an add-on to the routy I'm building. I already have a RTOS LinuxCNC with parallel port TB6560 and optical(IR LED) home switches. I don't know how accurate it will be yet but the motors can do 1.8 deg per step and I think the controller does 1/32 microstepping. Think it will work?
  3. lewac
    lewac New
    That will certainly work. however you don't require ANY microstepping for a router (unless you are make really tiny things). You do need IR home switches though (not physical ones, they bounce and are way too slow for definitive work). typical routers though are not in much of a hurry to do anything as most assuredly you'll burn the work up and/or your cutting tool!
  4. cooldan
    cooldan New
    http://xdztst.netii.net/
    check out this project i made... you need a OpenGL compatible browser ( notice, it works correctly if show some FPS counter on left side of screen and some arrows near the textbox's to change the XYZ values... then it submit.
  5. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Cooldan,
    Welcome to the forum.
    I give up, what is it ??
    Tweakie.
  6. Mark Carew
    Not showing up in Chrome :cry:
  7. cooldan
    cooldan New
    hi, and thanks.. well it should work in chrome.. i think the animation only work in chrome.. try to update it...
    its some robot arm, i make the code for arduino control 3 servos (180º) so the robot "hand" move as a CNC... with XYZ coordinates...
    im sorry for the bad english :p if anyone is interested i can share the code and the concept :p
  8. Mark Carew
    That sounds very cool but cannot get it to work.
    It will not show up at all in Chrome (latest version) but does show up in IE and I can rotate it around zoom in and out and such but thats it the submit does nothing at this point for me at least.
  9. cooldan
    cooldan New
    well were is the "real" arm :p its my first prototype xD
    it work in my chrome, it must have WEBGL activated, it should look like this... [​IMG]
    and move after hit submit...
    last try, check this website: http://threejs.org/ if any of the samples work, my site should work too..
    thanks for the replys :)
  10. Mark Carew
    Ok it's working now (needed hardware acceleration turned on in Chrome settings) very cool the way it moves nice job!
  11. David the swarfer
    you need to replace all those servos with metal gear digitals. this will give you much higher resolution and smoother movement, though I suspect some of your jitters are from your software. digital servos could be updated at 400hz so you could micro step from position to position.
  12. David the swarfer
    if you use belt/chain/cable drives, you DO need microstepping (unless you have some sort of reduction between the motor and the belt drive, but even then...)
    in general, stepper motors run better with microstepping as it helps to avoid resonance, so use it if you have it even if your application does not need it for resolution.
    what is a typical router? my woodworking router spins at 24000 rpm and cuts as fast as I can push it. in fact if I feed too slow, THAT is when it burns the wood. advocating slow feed speeds is counter to the science of cutting.
    The CNC router I use will happily cut plywood at 2000mm/min at 30000rpm.
    Please see my extensive posting on feed speeds in the OX build thread.
    In short, use existing science to calculate feed speed. If your machine is not stiff enough at that speed, reduce only the depth of cut, for example, with a 1/8" bit, instead of 1/16" depth, use 1/32" per pass.
  13. Tweakie
    Moderator
    Excellent advice David. :thumbsup:
    Tweakie.
  14. gary krig
    gary krig New
    I cannot find the pnp 4 axis machine?
  15. Mark Carew
  17. gary krig
    gary krig New
    Thanx.
    I will look at those......
    Gary
  18. ljvb
    ljvb Well-Known
    Not cheap.. not expensive.. for what it is, but Opulo is a pnp based on the Acro.. originally, not much left of the original acro. It is by Stephan Hawes, it is fully opensource (even the custom board he built to control it), but he has kits available. You will need a 3d printer to make the plastic bits.
