XYZ Position Indicator is disabled
Discussion in 'General Talk' started by Stacey Miller, Aug 31, 2020.
  1. Stacey Miller
    Hi Guys,
    I have my machine up and running now (Just tonight) On my Control software where it displays the location of X,Y,and Z Axis it just says disabled. What the Heck??? anyone seen this problem??? Also I tried homing my machine a 1500 X 1000 WorkBee with Lead Screws ..... My limit switches are working but it is not homing ..... it says I need to configure the size of my machine, I just chose the 1510 Workbee in the drop down list for configuration... Any help Would be Greatly appreciated!!!!
      File size:
      116.5 KB
      22
    Troubleshooting tab > Application Diagnostics button on the menu at the top. Untick Disable DRO (mustve gotten clicked accidentally at some point)
  3. David the swarfer
    read this gnea/grbl
    then set $130 $131 $132 to the correct values
    In OpenBuildsCONTROL click the 'GRBL settings' tab and change the values, then click 'Save to firmware' button at top left
    Which the profile does set too - perhaps you did forget to click Save and then reset when prompted (some settings take effect after restarting Grbl)
  5. CNCDungeon
    Thanks much Peter I just utilized your answer to address similar issue with DRO function to re-enable XYZ coordinate reading on GCODE sender
