Control Software not interpreting .gcode correctly for arc
Discussion in 'Control Software' started by PIOPIO, Feb 16, 2022.
  1. PIOPIO
    PIOPIO New
    I am getting some strange behavior for the open builds Control software. It is inverting one of my arcs and skipping an entire part of my cut. The .gcode behaves normally and as excepted in other software. Please help. Using an in house post processor, but I have had zero issues with it prior to this. Other arcs and lines are not affected by this in the same sketch either.
    OpenBuilds Control:
    NCViewer:
    #1 PIOPIO, Feb 16, 2022
  2. PIOPIO
    PIOPIO New
    The error could possibly be isolated around line 13197: G3 X340.122 Y1914.37 R44.45 where the arc is created.
    #2 PIOPIO, Feb 16, 2022
    If it fails to calculate the arc, the only reason is the numbers are off. We're just the symptom of an issue with the Post...
    Also, Grbl prefers IJK arcs, don't use the R format
    Note what Grbl's own developer says: "It's just not recommended". Change your post to use the better IJK format instead and all will be peachy
  4. David the swarfer
    agree with the 'dont use R format'...
    as an aside, many of your line segments in the Gcode are about 0.1mm long.
    This means your file is 16000+ lines long when it could be much shorter, and all machines will cut smoother with longer lines segments (unless the short segments are actually part of a curve), but yours ar enot, since we see code like this
    Code:
    X66.114 Y1807
    X66.163
    X66.263
    X66.362
    X66.411
    X66.461 Y1807.01
    X66.51
    X66.708
    X66.758
    X66.807 Y1807.02
    X66.857
    X66.906
    X67.005
    X67.054
    X67.104
    X67.153 Y1807.03
    X67.202
    X67.252
    X67.301
    X67.4
    X67.449
    X67.498 Y1807.04
    Which is really a collection of tiny X movements with occasional tiny Y movements (0.01mm, can your machine even step 0.01mm?). Quite inefficient.
    My rough and ready filter script reduces your file to ~1600 lines by keeping only movements longer than 1mm. loads faster, cuts faster, screen redraws faster. but this should really be done in the post, and try to avoid all the little the 'single axis' moves since they do mess with my filter.
  5. David the swarfer
    @Peter Van Der Walt - you do have to look at the OB display code. from about line 9170 in his file there is a long string of small motions without G1, many many lines before it gets to the 'faulty' G3, and that section does not display correctly until I add a G1 every few pages in my editor.
    @PIOPIO - the correct IJK format of that G3 would be
    Code:
    g1 X295.759 Y1956.04
    G3 X340.122 Y1914.37 I44.822 J3.265
    The I and J are offsets from the start of the arc (in the preceding G1). GRBL always uses incremental mode, there is no other option here.
    Further to my comment on the many tiny movements, If I filter out as many of the X (or Y) only movements as possible I get a very nice curve with ~1mm movements instead of 0.1mm movements.
    His post should add the G1 after that M8 at 9167 though so the parser knows we are in a G1 block
  7. PIOPIO
    PIOPIO New
    Thanks for the replies Peter and David. I ended up finding a workaround, but some really good comments on how to improve our post and we're implementing the suggestions you guys have made. Hopefully won't run into this issue again. Thank you for the prompt and knowledgeable responses!
