Hooking up the Interface.
Discussion in 'Interfaces' started by Richard Gallatin, Feb 20, 2022.
  1. Richard Gallatin
    I have a Millright CNC i am trying to use the Blackbox and Interface with. My machine works with the Openbuilds Software and the Blackbox. I have updated the firmware with no issues. When I plug in the Interface and turn everything on my Interface does all the test and show OK. When that is done it restarts and does not seem to load my GRBL settings. I am guessing that the Blackbox and Interface needs to be plugged into my computer and the flash drive into the interface.
  2. Richard Gallatin
    OK I figured it out. I had my Blackbox plugged into computer with USB I did not need to do that.
    Correct. Either USB or Aux, both cannot be active at the same time
