My Z AXIS freeze
Discussion in 'CNC Mills/Routers' started by bubbatay, Feb 23, 2022.
  1. bubbatay
    bubbatay New
    Ran jobs with no problem all week and now about 3/4 through the job the Z AXIs stops. Restarted program and computer. Z AXIS works fine. I'm afraid to start a new job after ruining 2.
  2. Alex Chambers
    We need a lot more info to be able to help - to start with what controller, stepper drivers and control software are you using and what machine do you have?
    What cad/cam software? Post your cad file and your g-code file please.
    If its been in use for a while, intermittendly stopping motor could also be a symptom of a wiring break in the motor wiring
    Futher to above advice, could also be an overheating stepper driver. Dial current down a little as a test
