3DS Cube 3 Modular Extruder
Discussion in '3D printers' started by Tom Dirriwachter, Mar 19, 2017.
  1. Tom Dirriwachter
    Tom Dirriwachter Well-Known
    Tom Dirriwachter published a new build:
    #1 Tom Dirriwachter, Mar 19, 2017
  2. Tom Dirriwachter
    I will reserve this post for relevant discussion additions.
    Please know that I have availability to some advanced tools. Most of this requirement can be brought down to simpler methods.
    I encourage people to help others achieve such feats by helping to develop simpler methods of achieving the same thing.
    We own the tools to do this. Printed solutions helps a lot!
    This is an angle plate I used on my watchmaker's lathe/mill to get a 15 degree angle. M6 threads were to mount the vise were printed in the model!
    This allows for very simple thread chaser, rather than a full blown tap. Thread chasers can be made with a simple screw and a Dremel cut-off wheel.
  3. chris foster
    hi there, I did the same thing a while back but I do not know where to get the the proper tubing and metal screw thingys, got any ideas
  4. Tom Dirriwachter
    All mine come from eBay. Bowden tubing 4mm PD 2mm ID PTFE [Teflon]; PC4M5 is the fitting code you want.
    Also find me on Thingiverse as 'Qube3Bot' - printable solutions A-Z.
    Thanks for reaching out. Come join the Print3Dforum.com and find treasures for your Cube 3 printer.
  5. chris foster
    hi thanx for the reply I might have made a boo boo, I already ordered the kit, BUT I ordered
    PC4-M6 Pneumatic Straight Fitting 4mm OD tubing M6 Reprap 3D Printer Bowden Tube, I hope that will work it's for a cube 3......thank you for your help!! chris
  6. Tom Dirriwachter
    I chose M5 for the tighter thread pitch. M6 will work fine.
  7. theracermark
    HI there
    I have 2 new in box original cubes I have attempted to use them and it is just too much trouble. I plan on converting to ramps boards and was going to sort out how to use the cartridges. is there a simple way to flash the existing board with something that will let the cartridges be reused? I liked the mod you did and that would be one I would do. Thanks for this idea and if you have any info on my question thanks in advance.
    Mark
