OpenBuilds Control and RPi
Discussion in 'Control Software' started by John Davies, Jun 18, 2019.
Tags:
  1. DarkPenguin
    DarkPenguin Well-Known
    Anyone created a docker container of this?
  2. JustinTime
    What is a 'docker container'? I use the RPi 3B with a Teensy. I 3d printed a case the holds both and has the fan for the RPi mounted to the case. Is that what you're talking about?
  3. Mark Mcleod
    Paul,
    I'm curious how you got Openbuilds Control to work on the Pi4? I'm running the latest stock Pi OS and have the Openbuilds Control on my desktop - whenever I click it and try either execute or execute in terminal, an hourglass pops up and nothing happens.
    Note the version it was tested against is mentioned in the Wiki (not latest as instructions hasn't been updated in a couple months) Follow the instructions closely. We might provide instructions for newer versions in time, but first someone will have to figure out what needs changing and contribute toward updating the install script or depencies etc as needed. Being an unofficial platform, it is hard to allocate work time to that, so if you do figure out what needs changing, let us know
  5. Mark Mcleod
    Just went back and reinstalled the legacy version of PiOS and it worked. The new version, and maybe the Pi 4, appear to have full GL and not the Fake KMS. The option to enable Fake KMS isn’t in raspi-config at all. Installing the legacy version allowed me to install Openbuilds.
  6. Ryan James
    What version of PiOS did you install?
    Use the version referenced in the Wiki
  8. Ryan James
    Ashamed to say I thought of that about 5 seconds after I posted.
  9. Mark_0815
    Mark_0815 New
    Hello
    I've running the Pi 4 2GB with Opnebuilds Control since a long time on the Blackbos.
    All works fine and I was very happy.
    Unfortunatly Openbuild Control will not longer start.
    In the past I have compiled the OBC software but I'm not a IT Hacker und I dont want to touch the running system for many years. ;)
    Now I want to understand that is happen.
    I've start no Update of the linux system.
    Nothing is touch. No new software. Nothing.
    It is possible that the start command for the OBC software download new files from git?
    git fetch --all; git reset --hard origin/master;
  10. Mark_0815
    Mark_0815 New
    I was brave and updated the Raspbian system.
    Then I restarted the compilation of OpenBuild Control.
    Five minutes later, the compilation went through without any serious errors.
    OpenBuild Control starts without problems!
    I am thrilled!
    It also seems to start faster.
    I hesitated for a long time because I had a lot of problems with the first compilation and I don't know why it worked at some point. :)
    But I seem to have resolved all dependencies properly at that time. This time the compilation was very easy.
    Many thanks to the OpenBuild Control community for their fantastic work!
    Regards
    Mark
    Translated with www.DeepL.com/Translator (free version)
  11. Mark_0815
    Mark_0815 New
    Hello friends
    I have again problems with Openbuilds Control on my RPi4.
    Without warning it does not start anymore.
    I have changed absolutely nothing. No update of the operating system.
    I suspect that Openbulds Control is downloading the latest version every time I start git.
    I then updated the Raspbian using apt.
    Did not help.
    Then deleted the openbuild folder and reinstalled completely.
    Also without success.
    The first error message that comes up is the following:
    Code:
    ~/OpenBuilds-CONTROL $ cd ~/OpenBuilds-CONTROL; git fetch --all; git reset --hard origin/master; MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y ~/OpenBuilds-CONTROL/node_modules/.bin/electron ~/OpenBuilds-CONTROL
    Fordere an von origin
    HEAD ist jetzt bei 17d8f51 v1.0.361
    App threw an error during load
    Error: No native build was found for platform=linux arch=arm runtime=electron abi=113 uv=1 armv=default libc=glibc node=18.12.1 electron=23.1.3
        loaded from: /home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings-cpp
        at load.resolve.load.path (/home/pi/OpenBuilds-CONTROL/node_modules/node-gyp-build/node-gyp-build.js:60:9)
        at load (/home/pi/OpenBuilds-CONTROL/node_modules/node-gyp-build/node-gyp-build.js:22:30)
        at Object.<anonymous> (/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings-cpp/dist/load-bindings.js:11:46)
        at Module._compile (node:internal/modules/cjs/loader:1174:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1229:10)
        at Module.load (node:internal/modules/cjs/loader:1044:32)
        at Module._load (node:internal/modules/cjs/loader:885:12)
        at f._load (node:electron/js2c/asar_bundle:2:13330)
        at Module.require (node:internal/modules/cjs/loader:1068:19)
        at require (node:internal/modules/cjs/helpers:103:18)
    Is this a real error or just a cosmetic error?
    Can anyone confirm if opbenbuildscontrol is currently running on the RPi?
    Am grateful for any help!
    Greetings
    Mark
    It does - staying up to date is important so all users has the latest bugfixes and features
    As its still Unofficial status, we don't test against the Pi. But for it to work well, in general, you just want an up-to-date OS, with the latest version of Node LTS, and the latest CONTROL.
    Your error looks like you may need to run electron-rebuild: OpenBuilds-CONTROL/pi-install.sh at master · OpenBuilds/OpenBuilds-CONTROL (The install script should have) to rebuild node-serialports bindings for ARM. Make sure to run an 'npm install' too to make sure all the latest dependencies are indeed installed
    If its not that, being unofficial, the community (i.e. you) will have to investigate and resolve, we cannot spend troubleshooting time on unofficial platforms unfortunately (Refer the warning along the top of the page at Installing on Pi4 ) and report back if docs or script needs updating
  14. Mark_0815
    Mark_0815 New
    Node is 19:
    Code:
    pi@raspberrypi:~/OpenBuilds-CONTROL $ node --version
    v19.8.1
    electron makes trouble:
    Code:
    > [email protected] postinstall
    > electron-builder install-app-deps
      • electron-builder  version=24.0.0
      • loaded configuration  file=package.json ("build" field)
      • executing @electron/rebuild  appDir=/home/pi/OpenBuilds-CONTROL arch=armv7l
      ⨯ node-gyp failed to rebuild '/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
    For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
    Error: EACCES: permission denied, unlink 'build/Makefile'
      failedTask=installAppDeps stackTrace=Error: node-gyp failed to rebuild '/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
        at NodeGyp.rebuildModule (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-type/node-gyp.ts:133:13)
        at ModuleRebuilder.rebuildNodeGypModule (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:93:5)
        at ModuleRebuilder.rebuild (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:129:8)
        at Rebuilder.rebuildModuleAt (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:203:9)
        at Rebuilder.rebuild (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:158:9)
        at installOrRebuild (/home/pi/OpenBuilds-CONTROL/node_modules/app-builder-lib/src/util/yarn.ts:29:5)
        at installAppDeps (/home/pi/OpenBuilds-CONTROL/node_modules/electron-builder/src/cli/install-app-deps.ts:59:3)
    npm ERR! code 1
    npm ERR! path /home/pi/OpenBuilds-CONTROL
    npm ERR! command failed
    npm ERR! command sh -c electron-builder install-app-deps
    npm ERR! A complete log of this run can be found in:
    npm ERR!     /home/pi/.npm/_logs/2023-03-15T22_46_04_606Z-debug-0.log
    (9/10) Recompiling OpenBuilds-CONTROL dependencies...
    npm ERR! code 1
    npm ERR! path /home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings
    npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    npm ERR! prebuild-install warn install No prebuilt binaries found (target=19.8.1 runtime=node arch=arm libc= platform=linux)
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using [email protected]
    npm ERR! gyp info using [email protected] | linux | arm
    npm ERR! gyp ERR! clean error
    npm ERR! gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
    npm ERR! gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/OpenBuilds-CONTROL/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings
    npm ERR! gyp ERR! node -v v19.8.1
    npm ERR! gyp ERR! node-gyp -v v9.3.1
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/pi/.npm/_logs/2023-03-15T22_46_14_393Z-debug-0.log
    up to date, audited 556 packages in 4s
    81 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    ✔ Rebuild Complete
    (10/10) Creating Menu and Desktop Shortcuts...
    [COMPLETE] Install Complete!  Thank you!
    Looks like a permissions problem - chmod/chown etc - check why the running process was denied access
  16. Mark_0815
    Mark_0815 New
    OK, I've solve this problem with rm
    npm cache clean --force
    Now the install script run a little bit longer :)
    First Error:
    Code:
    make: Verzeichnis „/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
      CXX(target) Release/obj.target/bindings/src/serialport.o
    In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-local-handle.h:12,
                     from /home/pi/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:12,
                     from /home/pi/.electron-gyp/23.1.3/include/node/v8.h:24,
                     from /home/pi/.electron-gyp/23.1.3/include/node/node.h:79,
                     from ../../../nan/nan.h:60,
                     from ../src/./serialport.h:13,
                     from ../src/serialport.cpp:1:
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
     constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
     constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
         kApiSystemPointerSize == kApiInt64Size,
    Post the full log if there's more
  18. Mark_0815
    Mark_0815 New
    The complete log. It's a lot:
    Code:
    pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -
    [STARTING]  OPENBUILDS-CONTROL INSTALL SCRIPT:
                Please wait for each step to complete.
    (1/10) Updating Repositories...
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_19.x buster InRelease
    Paketlisten werden gelesen... Fertig
    (2/10) Upgrading RaspiOS...
    Abhängigkeitsbaum wird aufgebaut.
    Statusinformationen werden eingelesen.... Fertig
    Paketaktualisierung (Upgrade) wird berechnet... Fertig
    Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
      python-colorzero
    Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    (3/10) Installing remote desktop (TightVNC and XRDP)...
    tightvncserver ist schon die neueste Version (1:1.3.9-9+deb10u1).
      python-colorzero
    xrdp ist schon die neueste Version (0.9.9-1+deb10u1).
      python-colorzero
    (4/10) Installing GIT...
    git ist schon die neueste Version (1:2.20.1-2+deb10u8).
      python-colorzero
    (5/10) Installing NodeJS 19.x...
    ## Installing the NodeSource Node.js 19.x repo...
    ## Populating apt-get cache...
    + apt-get update
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_19.x/dists/buster/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    gpg: WARNUNG: Unsicheres Besitzverhältnis des Home-Verzeichnis `/home/pi/.gnupg'
    ## Creating apt sources list file for the NodeSource Node.js 19.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_19.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_19.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    ## Run `sudo apt-get install -y nodejs` to install Node.js 19.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    nodejs ist schon die neueste Version (19.8.1-deb-1nodesource1).
      python-colorzero
    (6/10) Updating npm...
    changed 16 packages in 7s
    16 packages are looking for funding
    (7/10) Downloading OpenBuilds-CONTROL source code...
    Klone nach 'OpenBuilds-CONTROL' ...
    remote: Enumerating objects: 13353, done.
    remote: Counting objects: 100% (467/467), done.
    remote: Compressing objects: 100% (174/174), done.
    remote: Total 13353 (delta 258), reused 344 (delta 218), pack-reused 12886
    Empfange Objekte: 100% (13353/13353), 124.02 MiB | 1.57 MiB/s, Fertig.
    Löse Unterschiede auf: 100% (7815/7815), Fertig.
    Checke Dateien aus: 100% (703/703), Fertig.
    (8/10) Installing OpenBuilds-CONTROL dependencies...
    npm WARN skipping integrity check for git dependency ssh://[email protected]/noopkat/browser-serialport.git
    npm WARN deprecated @npmcli/[email protected]: This functionality has been moved to @npmcli/fs
    npm WARN deprecated [email protected]: Please use @electron/notarize moving forward.  There is no API change, just a package name change
    npm WARN deprecated [email protected]: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
     constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
     constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
     constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
     constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
     static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
     static_assert(1ULL << (64 - kBoundedSizeShift) ==
                       kMaxSafeBufferSizeForSandbox + 1,
    /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
     static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
    In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-object.h:10,
                     from /home/pi/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:13,
    /home/pi/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:256:44: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated [-Wdeprecated-declarations]
       using CopyablePersistent = Persistent<T, CopyablePersistentTraits<T>>;
    /home/pi/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:255:48: note: declared here
     struct V8_DEPRECATED("Use v8::Global instead") CopyablePersistentTraits {
    In file included from ../src/./serialport.h:13,
    ../../../nan/nan.h:206:16: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated [-Wdeprecated-declarations]
         public v8::CopyablePersistentTraits<T> {};
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:60,
    /home/pi/.electron-gyp/23.1.3/include/node/node.h:991:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.electron-gyp/23.1.3/include/node/node.h:1025:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    make: *** [bindings.target.mk:128: Release/obj.target/bindings/src/serialport.o] Fehler 1
    make: Verzeichnis „/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird verlassen
    Error: `make` failed with exit code: 2
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm ERR! code 1
    npm ERR!     /home/pi/.npm/_logs/2023-03-16T09_45_11_959Z-debug-0.log
    npm ERR! code 1
    npm ERR! • electron-builder  version=24.0.0
    npm ERR!   • loaded configuration  file=package.json ("build" field)
    npm ERR!   • executing @electron/rebuild  appDir=/home/pi/OpenBuilds-CONTROL arch=armv7l
    npm ERR! make: Verzeichnis „/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
    npm ERR! make: Verzeichnis „/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird verlassen
    npm ERR!   ⨯ node-gyp failed to rebuild '/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
    npm ERR! For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
    npm ERR!
    npm ERR! Error: `make` failed with exit code: 2
    npm ERR!
    npm ERR!   failedTask=installAppDeps stackTrace=Error: node-gyp failed to rebuild '/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
    npm ERR!        at NodeGyp.rebuildModule (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-type/node-gyp.ts:133:13)
    npm ERR!     at processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm ERR!     at ModuleRebuilder.rebuildNodeGypModule (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:93:5)
    npm ERR!     at ModuleRebuilder.rebuild (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:129:8)
    npm ERR!     at Rebuilder.rebuildModuleAt (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:203:9)
    npm ERR!     at Rebuilder.rebuild (/home/pi/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:158:9)
    npm ERR!     at installOrRebuild (/home/pi/OpenBuilds-CONTROL/node_modules/app-builder-lib/src/util/yarn.ts:29:5)
    npm ERR!     at installAppDeps (/home/pi/OpenBuilds-CONTROL/node_modules/electron-builder/src/cli/install-app-deps.ts:59:3)
    npm ERR! In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-local-handle.h:12,
    npm ERR!                  from /home/pi/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:12,
    npm ERR!                  from /home/pi/.electron-gyp/23.1.3/include/node/v8.h:24,
    npm ERR!                  from /home/pi/.electron-gyp/23.1.3/include/node/node.h:79,
    npm ERR!                  from ../../../nan/nan.h:60,
    npm ERR!                  from ../src/./serialport.h:13,
    npm ERR!                  from ../src/serialport.cpp:1:
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
    npm ERR!  constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
    npm ERR!                                                               ^~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
    npm ERR!                                                  ~~~~~~~~~~^~~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
    npm ERR!  constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
    npm ERR!                                                             ^~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
    npm ERR!      kApiSystemPointerSize == kApiInt64Size,
    npm ERR!      ~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
    npm ERR!  constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
    npm ERR!                                  ~~~~~^~~~~~~~~~~~~~~~~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
    npm ERR!  constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
    npm ERR!                                             ~~~~~~^~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
    npm ERR!  constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
    npm ERR!                                                    ~~~~~^~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
    npm ERR!  constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
    npm ERR!                                                  ~~~~~~~~~~~^~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
    npm ERR!  static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
    npm ERR!                ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
    npm ERR!  static_assert(1ULL << (64 - kBoundedSizeShift) ==
    npm ERR!                ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~
    npm ERR!                    kMaxSafeBufferSizeForSandbox + 1,
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
    npm ERR!  static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
    npm ERR!                ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-object.h:10,
    npm ERR!                  from /home/pi/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:13,
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:256:44: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated [-Wdeprecated-declarations]
    npm ERR!    using CopyablePersistent = Persistent<T, CopyablePersistentTraits<T>>;
    npm ERR!                                             ^~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:255:48: note: declared here
    npm ERR!  struct V8_DEPRECATED("Use v8::Global instead") CopyablePersistentTraits {
    npm ERR! In file included from ../src/./serialport.h:13,
    npm ERR! ../../../nan/nan.h:206:16: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated [-Wdeprecated-declarations]
    npm ERR!      public v8::CopyablePersistentTraits<T> {};
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    npm ERR! ../src/serialport.cpp: At global scope:
    npm ERR! ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
    npm ERR!  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    npm ERR!                             ^
    npm ERR! ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
    npm ERR!  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    npm ERR!                               ^
    npm ERR! In file included from ../../../nan/nan.h:60,
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/node.h:991:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    npm ERR!        (node::addon_register_func) (regfunc),                          \
    npm ERR!                                            ^
    npm ERR! /home/pi/.electron-gyp/23.1.3/include/node/node.h:1025:3: note: in expansion of macro ‘NODE_MODULE_X’
    npm ERR!    NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    npm ERR! ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
    npm ERR!  NODE_MODULE(serialport, init);
    npm ERR! make: *** [bindings.target.mk:128: Release/obj.target/bindings/src/serialport.o] Fehler 1
    npm ERR!     /home/pi/.npm/_logs/2023-03-16T09_47_56_536Z-debug-0.log
    changed 1 package, and audited 556 packages in 5s
    ⠸ Building module: bindings, Completed: 0make: Verzeichnis „/home/pi/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
    ⠴ Building module: bindings, Completed: 0In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-object.h:10,
    ⠋ Building module: bindings, Completed: 0In file included from ../src/./serialport.h:13,
    ⠹ Building module: bindings, Completed: 0../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ⠸ Building module: bindings, Completed: 0../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ⠏ Building module: bindings, Completed: 0  CXX(target) Release/obj.target/bindings/src/serialport_unix.o
    ⠙ Building module: bindings, Completed: 0In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-object.h:10,
                     from ../src/serialport.h:13,
                     from ../src/serialport_unix.cpp:2:
    ⠦ Building module: bindings, Completed: 0In file included from ../src/serialport.h:13,
    ⠼ Building module: bindings, Completed: 0../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:179:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:89:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ⠦ Building module: bindings, Completed: 0  CXX(target) Release/obj.target/bindings/src/poller.o
    ⠇ Building module: bindings, Completed: 0In file included from /home/pi/.electron-gyp/23.1.3/include/node/v8-object.h:10,
                     from ../src/poller.cpp:1:
    ⠸ Building module: bindings, Completed: 0In file included from ../src/poller.cpp:1:
    ⠇ Building module: bindings, Completed: 0  CXX(target) Release/obj.target/bindings/src/serialport_linux.o
    ⠋ Building module: bindings, Completed: 0  SOLINK_MODULE(target) Release/obj.target/bindings.node
    ⠸ Building module: bindings, Completed: 0  COPY Release/bindings.node
    ✔ Rebuild Complete
  19. Peter Van Der Walt
    Nothing pops out as obvious - could be Make versions, build-essentials versions etc (deprecation warnings)
    Will spin up a clean copy of RaspiOS when I get a chance (might not be today) and see
  20. Mark_0815
    Mark_0815 New
    Thank you for your help!
    This is not self-evident and I appreciate it very much.
    Especially because the Pi is not officially supported.
    If you can confirm that it runs on a clean installation I will rebuild the Pi.
    I'm not in a hurry, I don't have any urgent milling projects at the moment. I'm also using a laptop, which is fine for a bit of milling, but it won't survive in the long run because of the dust.
    A quick feedback on the Pi:
    Openbuild Control works fine on a Pi4 with 2GB Ram and the original 7" touch display.
    I've been milling with it for about a year and have no problems. No crashes and no hangups. My milling jobs are not very big though. No 3D surface machining.
    The nice thing about the Pi with the touch display is the compactness and extreme dust immunity.
    I would be very happy if the Pi would continue to be supported unofficially.
    Tip for all those who are considering using the Pi for control:
    In the beginning I often had the milling machine stop and Openbuild Control had to be reconnected to the black box.
    The problem was the very long power supply line into my workshop, more than 30m over a thin cable. The milling motor was interfering with the power supply to the black box during load fluctuations, causing the USB connection to break down.
    Now I use a separate power supply cable for the milling motor. Since then there are no more problems.
  21. Peter Van Der Walt
    If you have a moment and a spare SD, you might get that test done before I get a spare moment :)
    Great to hear - tough call on supporting Pi as an "official" platform is the occational linux quirks (IT support not related to CONTROL) that non-linux users have troubles with
    As long as we support x86/64 based linux, it should run on the Pi too - so unlikely to go away - but with all the recent update work, possibly just something that needs to be newer (newer base RaspiOS, newer node, newer build-essentials, something like that)
  22. Mark_0815
    Mark_0815 New
    I do it now :)
  23. Peter Van Der Walt
    Sweet! Try the latest - about time we get that up to date :)
  24. Mark_0815
    Mark_0815 New
    Dont work :-(
    Code:
    Empfange Objekte: 100% (13353/13353), 124.02 MiB | 1.37 MiB/s, fertig.
    Löse Unterschiede auf: 100% (7815/7815), fertig.
    Aktualisiere Dateien: 100% (703/703), fertig.
      • executing @electron/rebuild  appDir=/home/mark/OpenBuilds-CONTROL arch=armv7l
    make: Verzeichnis „/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
    In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-local-handle.h:12,
                     from /home/mark/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:12,
                     from /home/mark/.electron-gyp/23.1.3/include/node/v8.h:24,
                     from /home/mark/.electron-gyp/23.1.3/include/node/node.h:79,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: warning: left shift count >= width of type [-Wshift-count-overflow]
      124 | constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is greater than or equal to the precision 32 of the left operand [-fpermissive]
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: warning: left shift count >= width of type [-Wshift-count-overflow]
      125 | constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is greater than or equal to the precision 32 of the left operand [-fpermissive]
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
      128 |     kApiSystemPointerSize == kApiInt64Size,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
      186 | constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
      204 | constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:206:61: error: non-constant condition for static assertion
      206 | static_assert((kSandboxGuardRegionSize % kSandboxAlignment) == 0,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
      220 | constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:222:46: error: non-constant condition for static assertion
      222 | static_assert(kSandboxMinimumReservationSize > kPtrComprCageReservationSize,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
      230 | constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
      231 | static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
      236 | static_assert(1ULL << (64 - kBoundedSizeShift) ==
      237 |                   kMaxSafeBufferSizeForSandbox + 1,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
      260 | static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
    In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-object.h:10,
                     from /home/mark/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:13,
    /home/mark/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:256:44: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated: Use v8::Global instead [-Wdeprecated-declarations]
      256 |   using CopyablePersistent = Persistent<T, CopyablePersistentTraits<T>>;
    /home/mark/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:255:48: note: declared here
      255 | struct V8_DEPRECATED("Use v8::Global instead") CopyablePersistentTraits {
    ../../../nan/nan.h:206:16: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated: Use v8::Global instead [-Wdeprecated-declarations]
      206 |     public v8::CopyablePersistentTraits<T> {};
    ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    /home/mark/.electron-gyp/23.1.3/include/node/node.h:991:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      991 |       (node::addon_register_func) (regfunc),                          \
    /home/mark/.electron-gyp/23.1.3/include/node/node.h:1025:3: note: in expansion of macro ‘NODE_MODULE_X’
     1025 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      486 | NODE_MODULE(serialport, init);
    make: Verzeichnis „/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird verlassen
      ⨯ node-gyp failed to rebuild '/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
      failedTask=installAppDeps stackTrace=Error: node-gyp failed to rebuild '/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
        at NodeGyp.rebuildModule (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-type/node-gyp.ts:133:13)
        at ModuleRebuilder.rebuildNodeGypModule (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:93:5)
        at ModuleRebuilder.rebuild (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:129:8)
        at Rebuilder.rebuildModuleAt (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:203:9)
        at Rebuilder.rebuild (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:158:9)
        at installOrRebuild (/home/mark/OpenBuilds-CONTROL/node_modules/app-builder-lib/src/util/yarn.ts:29:5)
        at installAppDeps (/home/mark/OpenBuilds-CONTROL/node_modules/electron-builder/src/cli/install-app-deps.ts:59:3)
    npm ERR! code 1
    npm ERR! path /home/mark/OpenBuilds-CONTROL
    npm ERR!     /home/mark/.npm/_logs/2023-03-16T16_02_46_773Z-debug-0.log
    npm ERR! code 1
    npm ERR!   • executing @electron/rebuild  appDir=/home/mark/OpenBuilds-CONTROL arch=armv7l
    npm ERR! make: Verzeichnis „/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
    npm ERR! make: Verzeichnis „/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird verlassen
    npm ERR!   ⨯ node-gyp failed to rebuild '/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
    npm ERR!
    npm ERR!
    npm ERR!   failedTask=installAppDeps stackTrace=Error: node-gyp failed to rebuild '/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings'.
    npm ERR!        at NodeGyp.rebuildModule (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-type/node-gyp.ts:133:13)
    npm ERR!     at ModuleRebuilder.rebuildNodeGypModule (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:93:5)
    npm ERR!     at ModuleRebuilder.rebuild (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/module-rebuilder.ts:129:8)
    npm ERR!     at Rebuilder.rebuildModuleAt (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:203:9)
    npm ERR!     at Rebuilder.rebuild (/home/mark/OpenBuilds-CONTROL/node_modules/@electron/rebuild/src/rebuild.ts:158:9)
    npm ERR!     at installOrRebuild (/home/mark/OpenBuilds-CONTROL/node_modules/app-builder-lib/src/util/yarn.ts:29:5)
    npm ERR!     at installAppDeps (/home/mark/OpenBuilds-CONTROL/node_modules/electron-builder/src/cli/install-app-deps.ts:59:3)
    npm ERR! In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-local-handle.h:12,
    npm ERR!                  from /home/mark/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:12,
    npm ERR!                  from /home/mark/.electron-gyp/23.1.3/include/node/v8.h:24,
    npm ERR!                  from /home/mark/.electron-gyp/23.1.3/include/node/node.h:79,
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: warning: left shift count >= width of type [-Wshift-count-overflow]
    npm ERR!   124 | constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
    npm ERR!       |                                                 ~~~~~~~~~~^~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is greater than or equal to the precision 32 of the left operand [-fpermissive]
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: warning: left shift count >= width of type [-Wshift-count-overflow]
    npm ERR!   125 | constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is greater than or equal to the precision 32 of the left operand [-fpermissive]
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
    npm ERR!   128 |     kApiSystemPointerSize == kApiInt64Size,
    npm ERR!       |     ~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
    npm ERR!   186 | constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
    npm ERR!       |                                 ~~~~~^~~~~~~~~~~~~~~~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
    npm ERR!   204 | constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
    npm ERR!       |                                            ~~~~~~^~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:206:61: error: non-constant condition for static assertion
    npm ERR!   206 | static_assert((kSandboxGuardRegionSize % kSandboxAlignment) == 0,
    npm ERR!       |               ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
    npm ERR!   220 | constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:222:46: error: non-constant condition for static assertion
    npm ERR!   222 | static_assert(kSandboxMinimumReservationSize > kPtrComprCageReservationSize,
    npm ERR!       |               ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
    npm ERR!   230 | constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
    npm ERR!       |                                                 ~~~~~~~~~~~^~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
    npm ERR!   231 | static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
    npm ERR!       |               ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
    npm ERR!   236 | static_assert(1ULL << (64 - kBoundedSizeShift) ==
    npm ERR!       |               ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~
    npm ERR!   237 |                   kMaxSafeBufferSizeForSandbox + 1,
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
    npm ERR!   260 | static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
    npm ERR!       |               ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-object.h:10,
    npm ERR!                  from /home/mark/.electron-gyp/23.1.3/include/node/v8-array-buffer.h:13,
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:256:44: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated: Use v8::Global instead [-Wdeprecated-declarations]
    npm ERR!   256 |   using CopyablePersistent = Persistent<T, CopyablePersistentTraits<T>>;
    npm ERR!       |                                            ^~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/v8-persistent-handle.h:255:48: note: declared here
    npm ERR!   255 | struct V8_DEPRECATED("Use v8::Global instead") CopyablePersistentTraits {
    npm ERR! ../../../nan/nan.h:206:16: warning: ‘template<class T> struct v8::CopyablePersistentTraits’ is deprecated: Use v8::Global instead [-Wdeprecated-declarations]
    npm ERR!   206 |     public v8::CopyablePersistentTraits<T> {};
    npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    npm ERR!       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    npm ERR!       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    npm ERR! ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    npm ERR! ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    npm ERR! ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    npm ERR!       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!   412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    npm ERR!   433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    npm ERR!       |                            ^
    npm ERR!   452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    npm ERR!       |                              ^
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/node.h:991:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    npm ERR!   991 |       (node::addon_register_func) (regfunc),                          \
    npm ERR! /home/mark/.electron-gyp/23.1.3/include/node/node.h:1025:3: note: in expansion of macro ‘NODE_MODULE_X’
    npm ERR!  1025 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    npm ERR!   486 | NODE_MODULE(serialport, init);
    npm ERR!     /home/mark/.npm/_logs/2023-03-16T16_23_45_151Z-debug-0.log
    changed 1 package, and audited 556 packages in 6s
    ⠴ Building module: bindings, Completed: 0make: Verzeichnis „/home/mark/OpenBuilds-CONTROL/node_modules/@serialport/bindings/build“ wird betreten
    ⠦ Building module: bindings, Completed: 0In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-object.h:10,
    ⠦ Building module: bindings, Completed: 0In file included from ../src/./serialport.h:13,
    ⠏ Building module: bindings, Completed: 0../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ⠴ Building module: bindings, Completed: 0  CXX(target) Release/obj.target/bindings/src/serialport_unix.o
    ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
      179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
       89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ⠧ Building module: bindings, Completed: 0In file included from /home/mark/.electron-gyp/23.1.3/include/node/v8-object.h:10,
    ⠧ Building module: bindings, Completed: 0In file included from ../src/poller.cpp:1:
    ⠦ Building module: bindings, Completed: 0  CXX(target) Release/obj.target/bindings/src/serialport_linux.o
    ⠙ Building module: bindings, Completed: 0  SOLINK_MODULE(target) Release/obj.target/bindings.node
    ⠴ Building module: bindings, Completed: 0  COPY Release/bindings.node
    ✔ Rebuild Complete
    mark@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubusercontent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -openbuilds installing on Pi4openbuilds installing on Pi4openbuilds installing on Pi4TROL/master/pi-install.sh | bash -curl ntent.com/OpenBuilds/OpenBuilds-CONTROL/master/pi-install.sh | bash -curl -sL https://raw.githubus
  25. Reuben Morgan
    This is as a note for myself and anybody else that might run into the same problem.
    I ran into an issue during the install process on my Pi 4 regarding the serialport module; Error: No native build was found for platform=linux arch=arm...
    This was due to no prebuilt binary available for the pi and the npm install process not building it for some reason.
    I fixed it by doing the following:
    sudo npm install -g node-gyp node-pre-gyp
    cd node_modules/@serialport/bindings-cpp
    sudo node-gyp configure build
    After this CONTROL opes as expected.
    Source: Can't install on Raspberry Pi 4 · Issue #2534 · serialport/node-serialport
    JakeNull and Peter Van Der Walt like this.
  26. JakeNull
    JakeNull New
    I ran into this same issue while working on another project today.
    This saved me so much time. Thanks for posting this!
  27. ShaneTW
    ShaneTW New
    I am in the middle of collecting parts to run build a CNC plasma table using JD's Garage plans and I was looking for a low-cost, low maintenance computer setup for open builds and I happened to come across this. I was wondering if anybody has tried to run this on a Raspberry Pi 5 with 8gb of ram? I have several Raspberry Pi 3s and 4s I plan on testing this with, I'm just curious to try it out on a Raspberry Pi 5.
  28. BillyTheClown
    I run openbuilds control and lightburn on a cheep Windows 10 desktop computers, with a touch screen
    you could use the RPI instead of the windows system
    Here is my setup, I have 3 setups, one for each of my CNC
    I mount the touch screen right on the machine table
    Amazon.com
    Amazon.com
    Amazon.com
    Amazon.com
  29. kth
    kth New
    Before running black boxes I was running one with a Protoneer CNC board with external drivers. I originally used a 3B+ and it was marginal on running with the UI so I just connected remotely which was all I was looking for at that time. I didn't try a 4 but did go with a 5 when it released and it is very usable with the UI but I did go with an cheap SSD drive instead of the SD card. I had minimal if any issues getting it all installed and did some air cut testing but yet to find time to run it on one of my machines 8^(
