OpenBuilds Table Series
Discussion in 'Other Builds' started by OpenBuilds, Nov 27, 2020.
  1. OpenBuilds
    OpenBuilds Well-Known
    OpenBuilds published a new build:
  2. Jason Elford
    Any idea where one can get mdf at this size? I can only find 4’x8’.
    Use two smaller pieces, and use the L-brackets on the beam through the middle, to hold them together (feel free to add extra joints using biscuits, overlapping thinner sheets, etc)
    See, for example, you can make out the joint where the two sheets meet in this photo: (Circled in red)
  4. Jason Elford
    As usual, a prompt and helpful reply. Thanks!
  5. Rey Mendez
    I purchased and assembled a large table to fit a 1515 Lead machine. I like the table a lot, however it has one major shortcoming, at least for me. The caster plates are weak on this large table. I've already sent a support email regarding this issue, and I'm definitely NOT knocking the design. My shop floor isn't exactly what anyone could or would call smooth. It rough concrete, and since I have to roll my machine into and out of a work area, the caster plates have taken a beating. Has anyone else had this issue and what has been done to resolve it? Any help would be greatly appreciated!
  6. kurtblah
    kurtblah New
    I can't find any info on how much weight these tables are designed to hold. I'd really like to know before I build (a 5x10 and a 5x5).
    What are you intending on placing on it, happy to let you know if we think it will be too much
  8. kurtblah
    kurtblah New
    I really just need a couple of sturdy tables, I'll be using them for a lot of things rather than a single purpose. Maybe 200-300 pounds? Mobility is important. What would you think is the max weight for the 5x5 and 5x10 models, ballpark?
    It should be good to around 200-300 lbs yes
  10. Steven Dextraze
    Does anyone know the exact dimensions of the MDF on the1515 table top? Is it 68 inch by 68 inch? Just trying to plan ahead for the table build…
  11. Kevin Christenson
    After putting together a 1510 Table and putting a 1010 Enclosure on top of it (which is all great)...I'm left wanting some kind of drawers that would work well with this design. Mostly to store endmills and hold-down pieces. I've certainly found generic drawer designs, but hoping to find something that works with the aluminum extrusions of the table.
    One example that came to mind: Sliding Laptop Shelf For Openbuilds Table
  13. Kevin Christenson
    I did notice that shelf idea, and looks very nice for a work surface/keyboard/laptop drawer. However, I was concerned about the load capability of the v-wheels being used horizontally to hold a drawer full of tooling. How could I determine how much weight that could accommodate?
    Suitably sized it should be fine. Endmills and holddowns surely weighs less than some of those old laptops people prefer for the shops :)
    Can always do a trial run and add more wheels later but we don't think it will be an issue.
    Otherwise you could redesign the concept to use the wheels vertically :)
  15. DamonMcl
    DamonMcl New
    What is the recommended thickness of mdf for the 1010 table? Do you have the dimensions for the table top?
  16. Giarc
    The information regarding sizes is found here: OpenBuilds Modular Table Series There are also CAD models available.
  17. Evilspawn
    Evilspawn New
    I notice that none of the photos of the 1515 table show the bottom being used as a shelf, is there a problem with doing that?
    I was thinking of putting 3/4 Laminated MDF on the bottom to store some of my materials, would that be good as-is or should I add another support brace?
  18. Rick 2.0
    The video shows it being used with a shelf at around 1:15
  19. Evilspawn
    Evilspawn New
    It doesn't show if any extra support was used. I'm wondering if I should reinforce the shelf area?
  20. Rick 2.0
    T
    That's truly a function of how much load you intend to put on it and how much deflection you can accept. It is unlikely to fail, just merely flex. Besides, you will reach the load limit of the wheels (400 pounds total) before you max out the framing members. If you do feel the need to beef it up though, I would suggest another cross-framing member (dividing the lower bay into thirds) and screwing the MDF to the framing to increase overall rigidity of the table.
  21. Evilspawn
    Evilspawn New
    Gotcha. I actually took my wheels off and have it sitting on feet. I like the idea of adding a 3rd brace.
  22. Evilspawn
    Evilspawn New
    Is there a way to buy a 20601580mm rail to add under the table? I'm not sure if I'd have to just buy a 2000 and cut it down or if I could just get one pre-cut?
  23. Rick 2.0
    Contact the OpenBuild Part Store to see what they can work out. Contact Us : SUPPORT (openbuilds.com)
    Evilspawn likes this.
  24. Bryan Cope
    Could the 1510 table hold 1-2 pallets of half inch baltic birch? about 1800 lbs per pallet
  25. Peter Van Der Walt
    How to calculate V-Slot® deflection Might be a bit much - its M5 fasteners and 20x60/40x40 extrusions
  26. Bryan Cope
    Do you think it would hold 1000 lbs? has any testing been done yet to find its max capacity and suggested capacity? would something from 80/20 be a better fit for heavy duty use? I'm looking to be able to pull sheets from top and stack parts below.
  27. Rick 2.0
    4x4s and 2x8s would probably be your best bet.
  28. Jeff McAffer
    I'm looking for a table for my xcarve pro. They say it's about 350lb. Need capacity for material etc. Is there a way to beef up the 1515 table to handle that?
  29. Mark Carew
    I would say that you may find you have no problems with it hold that weight, but since its modular you can always quite easily add more supports where needed.
