libappindicator3-1
Discussion in 'Control Software' started by Jay Lytle, Feb 20, 2022.
  1. Jay Lytle
    Jay Lytle New
    it appears that debian bullseye no longer supports libappindicator3-1. any thoughts on a work around? i've found an article on a possible fix that indicates libayatana-appindicator is a suitable replacement, and i suppose you have to ln that to libappindicator3-1.
    thank you!!!
  2. Jay Lytle
    Jay Lytle New
    well, further research indicates that the .deb package has to be updated to reflect the new name libayatana-appindicator3-1 instead of the old name of libappindicator3-1. not sure exactly how to do that since i can't get it installed in the first place.
  4. Jay Lytle
    Jay Lytle New
    makes sense. my fix will be trying one step back on the debian since, as you correctly stated, it appeared once people upgraded to bullseye. apparently folks aren't happy about how it was handled. they could have just installed a fake library that did nothing more than redirect it to the new version for a couple of iterations, and then removed it once older software had time to update. to me, that would have made a much smoother transition, rather than just arbitrarily deciding, without warning to drop it completely.
    thank you for the info. this is more of an experiment. i'm working out having a backup solution in case my interface craters for any reason, i can still run my machine, with a low end computer cheaply. since i'm starting a side business, i want to have as many redundancies as i can to keep up and running as much as possible.
    :) You are correct, Linux maintaners shouldn't make life difficult for developers like this.
    Older version will be fine yes.
  6. JohnOCFII
    JohnOCFII New
