SharkBits Tool Database V3
SharkBits Tool Database that can be uploaded to Vectric and Auto Desk Fusion Software easily!
  1. OpenBuilds
    OpenBuilds Well-Known
    OpenBuilds submitted a new resource:
    SharkBits Tool Database - SharkBits Tool Database that can be uploaded to Vectric Software easily!
  2. Shannon M Hill
    Any Chance of a CSV file?
    Daniel Counterman and urko19 like this.
  3. jukeman60
    jukeman60 Well-Known
    hi all
    I unzipped the file and I could not load it into aspire 9.5 it did not recognise
    the .vtdb extension. I renamed the extension to .tool that's the extension that aspire 9.5 gives you
    received the following error
    error tooldatabase written by later version of program
    help?
    thanks mb
    urko19 likes this.
    Vectric is on v10 already, have you considered upgrading?
  5. urko19
    urko19 New
    Its possible to have a version for older versions of Aspire?
    I need it!!!
  6. Mike Nieman
    I just imported the Sharkbit library into Fusion 360 but now I want to just keep the 7 bits that I just purchased. The names or sku numbers don't match the Openbuilds parts numbers. How do I find these 7 bits I just bought in the kit?
  7. Mike Nieman
    I just want to know how to import Sharkbit data in Fusion360. The only Openbuilds option is Vectric.
  8. OpenBuilds
  9. Mike Nieman
    Thank you
  10. MWS
    MWS New
    Hi All
    I have the Sharkbits 3 flute surfacing bit but cannot see this in the database.
    Does anyone have the details of how and what to add?
    Regards
    MWS
    Øyvind Hodneland likes this.
  11. Pok3
    Pok3 New
    #11 Pok3, Jun 3, 2021
    Ayrianna likes this.
  12. Øyvind Hodneland
    I can't find the SB-7510 in the library. The face milling bit open builds sells... Where to find that?
    Not included in the library as yet, please add manually
  14. Øyvind Hodneland
    so where can I find cutting data?
    Matthew Williamson likes this.
  15. Matthew Williamson
    Did anyone ever get with you I am looking for the same information? If not did you find a different source? Any help would be appreciated.
    The database numbers are very Conservative anyway. It would not hurt basing your own items on the nearest similar bits, then do spend the time dialing in optimal values to get the best from your tooling.
  17. jonathan bennett
    is there a Sharkbits tool data base for any other programs?
    Not at this time, sorry
  19. OpenBuilds
  20. OpenBuilds
  21. OpenBuilds
  22. Michael RW
  23. Armour
    Armour New
    Anyone know how to import into Carveco?
    it says only .tdb
  24. Peter Van Der Walt
    For CAMs where you cannot import the database, you are welcome to recreate it, or setup toolpaths manually: See sharkbits [OpenBuilds Documentation]
  25. Armour
    Armour New
    Thank you sir.
