How to program ring light start/stop?
Discussion in 'CNC Mills/Routers' started by GoblinSpanker, May 9, 2022.
  1. GoblinSpanker
    Hello fellow CNC’ers,
    I’ve finally got my cnc up and running properly. I’ve installed the ring light and checked that it works properly. I can manually turn it on/off in the open builds control software. I’m normally controlling my CNC via the Blackbox and Interface. I have scoured the interweb to the best of my ability to try to find out how to program the black box to automatically turn on/off the ring light when a project starts/stops. So far it seems I need to put the code (M8 and M9) in to the header and footer? Or am I completely off? If anyone can point me in the right direction, it’d be much appreciated.
    Oh, and one more thing on another topic. It happens quite often when I’m done with one tool path and then go to start the next, that the usb drive or interface acts up. The interface says it can’t read it, or something to that effect. I’ve used the wizard multiple times to prepare the usb drive for use with the interface and I’ve tried several different usb drives. All formatted and setup via the wizard in OB’s control software. I doubt it’s the usb drives. I’ve checked that I’ve updated the firmware in the interface. Any ideas?
    thanks in advance,
    René
    100% correct
    For Interface issues, contact the store via Support > New Ticket
  3. GoblinSpanker
    Thanks for your reply.
    Re the Interface I’ll open a new ticket.
    Re the ring light activation, I guess I didn’t explain it clearly enough. How do I actually program the M8/M9 commands into header/footer, so the black box knows to automatically turn on/off the ring light (cooler power) with every tool path? I can’t find where to do that. I’m guessing I should do it in the control software and then flash the settings to the black box via usb? If so, where in the Control software do I do that? Am I just being daft?
    Your CAM application generates the Gcode. Thus you enable Cooling in your CAM options, or the Post options.
    What CAM are you using?
  5. David the swarfer
    M8 is the 'flood coolant' code.
    So in your CAM software you need to set the flood coolant on for the tool, then the M8 will be output in the header and M9 in the footer.
  6. GoblinSpanker
    Thanks for both replies. I use Vcarve Pro. I will look for that setting, somewhere in the software. Never thought of looking in the CAM software.
  7. GoblinSpanker
    I would’ve never thought of looking to activate the light in Vcarve, much less the post processor. You something new every day. Anyway, with a bit of research I found it and it’s working perfectly now. Thanks so much for your help, guys.
    SOLUTION:
    Just in case someone else has the same problem, here is the solution to the Ring Light question. This is applicable for Vcarve Pro, although I’m guessing the process would be the same for any Vectric software and very similar for other types of cam software.
    Find the Gcode file you’re using for your cam software. If you can’t find it, open up Vcarve, Open ANY project, go to Machine Menu, select Machine configuration management, find your specific post processor where it says “Associated Post Processors, Click the “+” sign on the right hand side, find your post processor, right click, customize, open file location, open with Notepad, scroll down to “begin HEADER”, insert “M8” in the header (remember to write the quotation marks), do the same further down where it says “begin FOOTER” but instead of M8 write M9, save the file, select it in Mchine Configuration Management, restart Vcarve. Any toolpaths saved from here on will have your light turn on at the beginning, and light turn off at the end of the tool path.
  8. Derek Reich
    If I wanted to operate the ring light separately (with it's own wired inline on/off switch), what's the simplest way to just get power? I assume I don't need to go through the black box, and just wire to an open 24v port on the power supply?
    Correct, can go straight to the PSU's other spare output port.
    Older video (Before the PowerCase days)
  10. Derek Reich
    Okay, cool. It seemed like that would be the case. I did notice that in the video, there are no blocks on the underside of the spindle mount. Is that specific to the 1515? I assume I need to remove the spindle, motor, and the front plate to be able to remove the spindle mount and then place the ring light under the blocks on the underside. Is that correct?
