Blackbox X-port defect?
Discussion in 'Controller Boards' started by David Kater, May 10, 2022.
  1. David Kater
    Hi all,
    I am making a new thread, beceause I think I found the problem of the 'x-axis not backing up'. I managed to get the stuttering of the machine away by checking the 'invert step pulse' box, so that one is solved. Now remains the problem of the x-axis not backing up when homing. Also, when running a g-code, it rounds corners fine in the x-minus direction, but in the x-plus direction, it squares of corners, and when doing splines, it goes all jerky. I then swapped the X and Z motors around at the blackbox, so I connected the z-axis to the X-port, and the X-axis to the Z-port. Then suddenly, X worked fine! Now Z had the same issues. My clue is that probably the X-port on the blackbox is not working properly? Is there a way to check this?
  2. David the swarfer
    You have already tested for this and proved a faulty port, now you need to contact the store
    Submit a ticket
  3. David Kater
    Alright, I will do that, thanks!
  4. David Kater
    I submitted the ticket, but when I try to log into the support portal with the same password and e-mail as on this site, I get an error that the mail and password don't match. I also cant change my password, It says I am not authorised to access that panel, and that I should contact the helpdesk administrator, is that normal?
    Create ticket > Wait for reply email
    Login is for support agents
  6. David Kater
    Alright, I misunderstood the site, sorry:)
    Note the drivers inside BlackBox needs that DISABLED.
    Step Invert is for customers running other kinds of breakout boards and external drivers like DM/Q542s wired in Open Collector configuration
  8. David Kater
    alright, noted. but when they are disabled, i get crazy stutter. with it enabled on Y, it runs smooth. Could that be related to the defect part of the blackbox?
    We'll see when you get your replacement - i have some doubts, but lets eliminate hardware first, one less thing to check
