Question about OpenBuild's stepper motor wires...
Discussion in 'General Electronics' started by Tony LaBelle, May 11, 2022.
  1. Tony LaBelle
    Hello All - The stepper motors I've received from OB have a pin connector on each wire then connected into the black connectors for interface...what is the name of the pin connector. I would like to use them rather than tinning each wire then installing into black connector. Is there a dedicated tool crimper for this type of connector? Thanks in advance for the help!!! Tony
  2. sharmstr
    Check on amazon etc for a "Ferrule Crimper Set" - you get nice little kits with the crimping tool and a sortainer of different sized ferrules
    #3 Peter Van Der Walt, May 12, 2022
  4. Tony LaBelle
    Shawn / Peter Thanks for the response...Exactly what I'm looking for :thumbsup:
